You mean everything is upside down. All astronomical telescopes show upside down images. It's how they work. Nothing is wrong with your telescope. Read my Frequently Asked Questions-- TIP on my profile page.
Hey there, Sounds like the mirror is not moving out of the way for the sensor to see the image. Could be simple fix, or a broken lever. Remove the lens and see if anything looks out of line with the mirror.
Protein bars typically contain a combination of different proteins like
whey protein isolate, whey protein concentrate, milk protein, and soy protein
isolate.
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
hello, you may have done this already but try it anywhey go in to the menu click picture mode half whey down is the word reset click on to this it should make it brighter hope it helps
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
1 Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
1 Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Hey there bigbhoney, I would use your photo editing software, to create a mirror image of the picture or document. Nero will do this as well as windows photo viewer. Your printer probably came with this type of software as well. Good Luck!
