Question about KWorld DVB-S 100 (DVBS100) Video Capture
Kworld DVBs 100 with win vista
My card was working v.good with win xp but when i upgraded it to win vista i got the message (Access violation at address 00507366 in module DVBS.EXE. read of address 00000000) -your help will be very appreciated.pls
  • 3 more comments
  • compu_way Apr 20, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to ahmedlaa's Kworld DVBs 100 with win vista problem, and notify you when a new solution is offered.
  • Anonymous May 04, 2008
    lolo
  • yogi721 May 04, 2008
    ACCESS VIOLATION AT ADDRESS 00498728 IN MODULE DVBS.EXE READ OF ADDRESS 00000057
  • shadispire May 25, 2008
    i have Kworld DVB-s 100 and it was working well with win XP but now win win Vista and when i run the program it gives me the following message: "cannot render MPEG2 Demux filter" and when i press OK it gives me the next message: "Access violation at adress 00498728 in module 'DVBS.EXE'. Read of adress 00000057."
    so what i have to do, is there any version of dvbs plus for in Vista.
    thank you for help
  • Anonymous Sep 11, 2008
    i have the same problem
i have this problum how can solve this problum
Posted on Jun 13, 2008
I got a kworld tv card from Jaycar electronics Australia.I think its a tv 100.They have tried to give support for it and have Vista drivers,on their site.Error message is cant render demux filter or something similar
Posted on Jun 06, 2008
The best solution is to install driver as it, but you try to use skynet as a viewer program,
best wishes
Talal Tfiha
Latakia-Syria-0988684726
Posted on Feb 07, 2009
Jbnb bcbvcbvcbvcbcbbfvbvccbcb
Posted on Sep 02, 2008
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Kworld dvbs 100 pci card
my card work well ,but sometimes it's give an error message at start(violation adress ,,,,,,,,,,,00000000) ,,,,,thinks for inser,
May 09, 2009 | KWorld DVB-S 100 (DVBS100) Video Capture
Software upgrade
Hi!
Well, win xp is absolutly more fun as OS then win 2000:)
To upgrade to win xp will be no problem since Toshiba have drivers for ir. To upgrade to VISTA will...or can give you problem since there arent any drivers for that Tecra S1.
If u deside to upgrade to win xp, here is all the drivers u gona need to do it:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380605&rpn=PT831U&modelFilter=S1&selCategory=3&selFamily=1073768664&selModel=380605%7CPT831U
Good luck
Dont forget to RATE me
Nic
Mar 12, 2009 | Toshiba Tecra S1 Notebook
check this card if support in windows vista....if not! check in there website if the have available driver for vista.
Dec 11, 2008 | KWorld DVB-S 100 (DVBS100) Video Capture
My cd instalion damaged
Software is on their site; kworld.com.tw. If you cannot find, send an email to aikido44@aol.com and I will zip and send to you, or put on a hosting site for you to download. Good luck.
Sep 14, 2008 | KWorld DVB-S 100 (DVBS100) Video Capture
Dvb-s 100 problem
salut
prodlem de dvb-s 100 avec win xp
May 25, 2008 | KWorld DVB-S 100 (DVBS100) Video Capture
EMPIRE DVBS PLUS
access violation at adress 0049451D in module 'DVBS.exe' read of adress 00000000
May 11, 2008 | KWorld DVB-S 100 (DVBS100) Video Capture
The program dvbs plus do not start
well i have the same problem ndi works hard to fix it nd finally the only way is by repairing the system coz i think it is related to a codec problem which damage the DVB.EXE file.nd i succeed with this so just try it repair windows not formatting nd install media classic codic it could help u :D
Dec 05, 2007 | KWorld DVB-S 100 (DVBS100) Video Capture
KWorld ATSC 310U on Windows Vista 32bit Problems
Hi, the real problem here is VISTA, despite Microsofts hoopla this program is not as good as faithful old XP. The driver base is almost empty and a whole host of software and hardware just will not work with it. I reccomend you go back to XP until Microsoft releases a service pack with driver updates and then upgrade to VISTA. Regards mistyman
Oct 01, 2007 | Pinnacle Breakout Box & Drivers for...
Access violation in main center exe.
Try un-installing then re-installing the software for the usb stick.
Aug 07, 2007 | KWorld PVR-TV 305U (KW-PVR-TV305U) Video...
KWorld DVB-S 100 (DVBS100) Video Capture Logo
660 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Ruben Balisbis
Ruben Balisbis
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
