Question about Garmin eTrex Venture Cx GPS Receiver
Not connected When i plug my Garmen venture CX GPS into the computer with the USB cable on my GPS it says not connected, also on the computer a "new Hardware" icon comes up, but it says there is nothing connected to the computer. We thought it was the USB cord, but when we plug in my friends GPS his works fine. I was woundering if there was anyway this could be fixed.
  • Garmin Master
  • 638 Answers
Have you installed the USB drivers for your GPS to your PC? You can download the drivers from the Garmin website.
Posted on Apr 04, 2008
I have a garmen Nuvi 720, it charges on computer, but not on the sig. lighter, I thought first it is the cord, then I bought a new cord. nothing have changed. I though it might be a good idea if I just...
Hi, this may be result of errors in both hardware concept and respective operation system software. if you have any warranty time, then try to hand over that in order to collect new one. have fine as early
Dec 24, 2010 | Garmin n?vi 765T Car GPS Receiver
I have a nuvi 1350, how to register for later updates
with the unit Off
connect the gps to computer using the usb cable...( same usb cable most cameras use to hook to computers)
once connected your computer will detect new hardware (usb) minimise box
next
go to www.MyGarmin.com it to will detect your model number and let your register your gps
you will be asked to download WebUpDater utility to transfer files to your gps
Nov 20, 2010 | Garmin nuvi 1350 Car GPS Receiver
How do you download the latest maps
With the unit OFF
plug in your GPS to your computer using a USB cable ( its the same usb cable cameras use to connect to computer
your computer will detect new Hardware (usb port ) minimise the pop up box
next
go to www.MyGarmin.com register your unit there its free, and it will also detect your model of your gps and let you download the lastest Maps and Firmware
Garmin will tell you to download WebUpDater utility to transfers maps to your unit
Nov 11, 2010 | Garmin nuvi 205W GPS Receiver
How do i charge my 265 via computer
You charge it by using a Mini-USB to USB cable... Its the same USB cable most cameras use to connect to a computer
with the unit off plug in the USB to gps then to computer.....your computer will detect the new hardware (USB)
it will take a few hours to totally charge the gps this way
Nov 05, 2010 | Garmin n?vi 265WT Car GPS Receiver
How do I update my maps. All I have is the cable that connects from the USB on the back of the GPS to the cigarette lighter in my car
You need a mini-USB to computer USB cable..... ( most cameras use this same USB cable to connect to a computer)
with the unit off
plug in the mini-USB to gps and connect to computer USB port
the computer will detect new hardware
now go to www.MyGarmin.com
it will ask you to register, its free....
Garmin will detect your model and let you update your maps and firmware
it will also tell you to download WebUpDater utility to transfer to your gps
Nov 03, 2010 | Garmin nuvi 205W GPS Receiver
Why can't my PC detect Garmin 255W when I plug it via USB?
First makre sure that the usb is working. Just plug anythign into the usb port and if it detect it we know that is working.
Now with the GPS plug the usb cable into the port you tested then plug the gps on the other end. Watch your screen (PC) and see if it detects the gps. It should say one of two things. One will be device discovered Garmin GPS (something along that line) or it may show USB storage device. You can plug it in and look under my computer for these if you missed what it said. Some versions of windows are better than others at detecting whats connected. And some hardware is better than other at detecting something on a connected usb cable.
You should also plug the cable into a differant port if you had left it connected and were getting this problem. And you should try plugging both into a differant computer if you can. Doing these can tell you if the problem is the gps, the cable the port or the computer itself. Usually just changing the port is all it takes.
Apr 03, 2010 | Garmin nuvi 255W GPS Receiver
Cable connection wont go in all the way
Are you talking about the automobile charging cable or the USB cable to connect to your home computer? In either case, the mini USB plug should make contact in the back of the GPS without having to be inserted more than about 1/4". Note that one side of the socket is wider than the other, as is also the case with the plug.
At the other end (of the computer USB cable), the full sized USB plug should insert about 1/2". One thing that I've noticed on my Garmin cable is that the "GARMIN" is on the back side of the end that plugs into the computer. Most USB plugs have the USB icon on the front, but that's blank on the Garmin cable. If you attempt to insert the plug backwards, it won't go in all the way.
Good luck.
Mar 10, 2010 | Garmin GPS
Unlocking a Garmin etrex venture cx
The unit comes with a base map. You will need to purchase City Navigator software if you want more detailed maps which will show all roads. If the box contained a copy of the City Navigator and you threw away the code, you'll have to purchase another unlock code from Garmin.
May 22, 2008 | Garmin eTrex Venture Cx GPS Receiver
Moblie Mapper CE Cannot Link to desktop
On your Thales, go to Start> Settings> Control Panel, then find "PC connection". Open that and make sure "Enable direct connections to the desktop computer" is checked. Click "Change Connection" and make sure it says USB then hit OK. Hit OK again close Control Panel. Disconect the GPS from your computer and reconect. It should allow access now.
Mar 31, 2008 | Thales MobileMapper CE GPS Receiver
Garmin eTrex Venture Cx GPS Receiver Logo
434 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
