Home | Coleman | (5040B750) Patio Heater | Charmglow gas patio hea...
Coleman Patio Heater
Problem for Coleman (5040B750) Patio Heater
Charmglow gas patio heater
By dawnk on Mar 16, 2008
our patio heater is a little over a year old. It will not turn on. when you push the ignition switch you get a loud ticking sound, nothing happens.
the gas cannister is full and is operational, as it works on the grill.
thanks for any help.
Same Problem
May 16, 2009
-   I have the same problem with mine . the pilot light lights and goes out when i let go!! I've vacumed it out but it was pretty clean to begin with. ???? who knows?? -   Guest
May 15, 2009
-   PUSH KNOB IN PILOT LGHT STARTS ...LET GO AFTER 4 MIN LIGHT GOES OUT AND HEATER WONT START -   Guest
May 02, 2009
-   i have a charmglow heater ,i light it and it burns for five minutes and then goes out.-   Guest
Jan 18, 2009
-   same prollem, the pilot lights but when i let go the pilot goes out. when i turn to high or low pilot goes out. if i push in for pilot and then push the ignitor the pilot lights and stays lit as long as i am holding it in.. let go or try to set to low-high, flame goes out...-   guest86
Oct 05, 2008
-   The "sparker on mine is worker and I can see the spark but the pilot does not light. I was able to light the pilot with a lighter as long as a pressed down on the control know it stayed lit. Once I tried to turn the knob to low the pilot went out. I pressed the know for well over a minute and repated it 5 or so times. The propane tank is full.
any ideas.-   Guest
Best Solution
posted on Mar 20, 2008
Helpful)
hotuna
Rank: Guru
Rating: 86%, 315 votes
The ticking noise is the ignigtor. If the gas tank is full, and the regulator is on, then try lighting with a match or fire of some sort. Be careful of the spark-er! If it lights, then the spark needs to be adjusted so it catches the gas better. If it doesn't lite, then the hole for the pilot is plugged. An outside heater is common for a spider or other creature to make this his home. You need to clean it out. Compressed air even another flame may do it. if not It needs to be removed and cleaned out. If you can see the little hole, trey poking a thin piece of wire into it, it may get it.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 29, 2009
Somewhat Helpful)
Chpgitx
Rank: Apprentice
Rating: 75%, 2 votes
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Was this helpful?
Yes
No
Popular Solutions for Coleman Patio Heater
Questions and Unsolved Problems for Coleman Patio Heater
Do you recommend Coleman (5040B750) Patio Heater?
Answer
Answer
What does OH mean on a hot tub control panel
Answer
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and... (More)
Answer
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but... (More)
Answer
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve... (More)
Answer
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Patio Heater:
Top Heater Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
