Kenwood protection function
I have a KAC-8102D amplifier. I set off the protection Function on it and now i can not get it to work, the fuses are all fine, and i tried disconnecting and reconnecting everything with no luck. Is there somthing i need to do inside the amplifier. They need to make a little reset button that you press when the function kicks in :S. any help or suggestions?
  • Anonymous Sep 27, 2008
    same exact problem on my kenwood KAC 7204 amp...i agree with u 100% about the reset button
SOURCE: Middle Button does not work
mine dont work either....................julie
Posted on Mar 16, 2008
SOURCE: VB101PK REV 13, AMP WITH SUBWOOFERS
you may have to much speaker for the amp or one of ur wires could be crossed
Posted on Mar 17, 2008
robotek
  • 1512 Answers
SOURCE: Kenwood Amp blinking Standby indicator light
Hi fuxsiloh.
It sounds like you have eliminated all the things that could generate this symptom that are external to the amp. It is most likely that there is an internal problem that is causing the amp to go to protection mode. A power supply failure(maybe a fuse) is the only really user serviceable part inside the amp. Perhaps check for failed fuses, replacing any that may have blown with exactly the same type. BE SURE TO UNPLUG AT THE WALL FIRST:)
Is the amp still under warranty? If so, then returning it to a Kenwood service center is the shot. If you want to have a go at repairing it, I can talk you through it, but some experience with this sort of thing is very necessary. Good luck
regards
Graeme
Posted on Apr 06, 2008
robotek
  • 1512 Answers
SOURCE: kenwood vr5700 standby blinking light
Hi kerrijon
Oh dear, your budding lil electrician may have gotten out of his depth:).
Shorted speaker wires often result in damage to the amps output stages. The blinking light tells us that the unit has gone into protection mode, preventing damage to the speakers from the amp. It will have what is termed a DC offset condition being generated by the channel; that got shorted. There is no easy fix for this and you have checked the obvious with fuses and removing all speaker wires and checking operation. The unit will have a blown output transistor/array, possibly driver transistors, and fusible resistors, and diodes to that channel. The bias current will also need to be set up again once repairs are completed.
There are no user serviceable parts in a unit like this. With good knowledge of electronics, a multi meter, soldering iron and experience at using all, you could fault find the channel, replace the parts yourself. I should warn you that if descrete components are used, they can be difficult to repair because of the nature of DC coupled linear stages employed. The best option is to take it to a repair man for a quote.
I am happy to try and talk someone through a repair process, but there is a degree of difficulty ascociated with not being able actually work on the amp.
The best solution for you is to get a tech to look at it. This sort of repair work can range from $80-150 depending on the parts used and the time taken to fault find and replace parts. I hope that this helps you. Your appreciation for my time spent to give you this advice is best rewarded with a FixYa.
Cheers
regards
robotek
Posted on Sep 10, 2008
thadrizzle
  • 22 Answers
SOURCE: What is the watts of
It's a 2 channel 75 X 75RMS made in 1988. I repaired the circuit board but I cannot find a a power cable (kenwood part# E-30-2302-05). If anyone has a schematic or a din pin out for that I would love to see it or here from you.
Posted on Sep 22, 2008
Kenwood kac 628 red light comes on and no audio output
The red light you describe on your amp, is the protection mode warning light. An amp goes into protect for many reasons. Here's a checklist.
1st check the fuse (s) on your amp and make sure they are not blown.
2nd check the inline fuse next to your car battery (if you have an inline fuse)
3rd, disconnect the speaker wires with amp on, does the light go off?
4th check your ground, this may be ok if you have tried another amp with the same wires.
5th.if none of these turns the protect mode off, it may be an internal fault.
you may have blown transistors and it is a tricky job to repair and costly.
Jan 28, 2013 | Kenwood KAC-628 Car Audio Amplifier
Solve Your ''kenwood kac x40m problems'' Problem Now! the operation protection light is on never goes off subs dont work what do i do
your amp output transistors are shorted and protection is activated to protect your amp from bigger damage.if you are confident you can try to open the amp and you should see some burn marks or burnt(blown) transistor and just simply replace him.or take it to repair shop
Mar 21, 2010 | Kenwood KAC-X401M Car Audio Amplifier
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
How do i get my kenwood kac-8402 out of protection
first thing first open it up ull need to check ur heat sinks and capacitorsand see if any of them are blownd if there are blowend replace the bownd once. and try it
Jul 07, 2009 | Kenwood KAC-8402 Car Audio Amplifier
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Amp speaker level input pins
You could open the amp to see if the wires are labeled at the circuit board end. Other than that you would need a wire diagram or someone to give you their harness that they are not using. Should be a lot of them kicking around since most people use RCA's.
Sep 04, 2008 | Kenwood KAC-6402 Car Audio Amplifier
Kenwood Excelon KAC-X521
According to page 7 of the radio's manual, E-02 means the amp has failed and DC is being applied to the speakers. It also says "Turn the POWER switch "OFF" and release the protection."
Feb 09, 2008 | Kenwood Excelon KAC-X521 Car Audio...
235 people viewed this question
 Grubhead
Grubhead
