Question about MSI MS-6368 Motherboard
Stop error with windows 2003 can only run my computer on safe mode
I can only run my computer on safe mode. shutting down if not safe mode
my email: zinguim@yahoo.fr
    Sergeant:
    Champion:
  • 256 Answers
Hi
Try to restore windows in safe mode if not ram problem replace it.
Thanks
Posted on Mar 16, 2008
In dg41wv server 2003 is not loading
problems in Windows Server 2003
To start the computer by using Last Known Good Configuration, follow these steps:
Click Start, and then click Shut Down.
Click Restart, and then click OK.
When you see the message Please select the operating system to start, press the F8 key.
Use the arrow keys to select Last Known Good Configuration, and then press Enter.
Collapse this imageExpand this image
Note NUM LOCK must be off before the arrow keys on the numeric keypad will function.
If you are running other operating systems on the computer, click Microsoft Windows Server 2003 on the list, and then press Enter.
Notes
By selecting Last Known Good Configuration, you can recover from problems such as a newly added driver that may be incorrect for your hardware.
This feature does not solve problems caused by corrupted or missing drivers or files.
When you select Last Known Good Configuration, only the information in the following registry key is restored:
HKLM\System\CurrentControlSet
Any changes that you have made in other registry keys remain.
If you can start your computer by using the Last Known Good Configuration feature, the last change that you made to the computer (for example, the installation of a driver) may be the cause of the incorrect startup behavior.
if this fails to fix the problem try to repair in safe mode
How to start the computer in safe mode
When you start the computer in safe mode, Windows loads only the drivers and computer services that you need.
You can use safe mode when you have to identify and resolve problems that are caused by faulty drivers, programs, or services that start automatically.
If the computer starts successfully in safe mode but it does not start in normal mode, the computer may have a conflict with the hardware settings or the resources. There may be incompatibilities with programs, services, or drivers, or there may be registry damage. In safe mode, you can disable or remove a program, service, or device driver that may prevent the computer from starting correctly.
To troubleshoot startup problems in safe mode, follow these steps:
When you see the message Please select the operating system to start, press F8.
On the Windows Advanced Option Menu, use the arrow keys to select Safe Mode, and then press Enter.
Note Num Lock must be off before the arrow keys on the numeric keypad will function.
Do one of the following:
If the computer does not start in safe mode, try starting the computer by using the Recovery Console. If you still cannot start the computer, look for possible hardware problems, such as defective devices, installation problems, cabling problems, or connector problems. Remove any hardware that was added recently, and then restart the computer to see if the problem is resolved.
If the computer starts in safe mode, go to the next section to continue to troubleshoot the startup issue.
Use Event Viewer to identify the cause of the startup problem
View the event logs in Event Viewer for information that can help you identify and diagnose the cause of the startup problem.
To view events that are recorded in the event logs, follow these steps
Click Start, point to Administrative Tools, and then click Event Viewer.
Start the Event Viewer snap-in in Microsoft Management Console (MMC).
In the console tree, expand Event Viewer, and then click the log that you want to view. For example, click System log or Application log.
In the details pane, double-click the event that you want to view.
To copy the details of the event, click Copy, open a new document in the program in which you want to paste the event (for example, Microsoft Word), and then click Paste on the Edit menu.
To view the description of the previous event or the next event, press the UP ARROW key or the DOWN ARROW key.
Use this tool to help identify possible problem devices and device conflicts.
To do this, follow these steps.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
you might be able work your way through the problem
hope this helps
Sep 01, 2012 | INTEL - MOTHERBOARDS Dg41wv Uatx Intel Gma...
My system is automatically restarting
Please make sure that all memory modules inside of the comouter are seated tightly.
If everything inside the computer seems intact and the computer still reboots try to go to safe mode and check if will do the same.
From shutdown, turn your computer on and start tapping the F8 key (F5 for some computers) when the menu appears choose either safe mode or safe mode with networking. check if the computer would still restart in that mode.
If it doesn't: press and hold the windows key on your keyboard then press the letter R, when the Run box comes up type in msconfig go to the services tab, tick Hide all Microsoft services and the click Disable All. Go back up to the tabs and click start up click Disable all then restart the computer.
If it still restarts in normal mode check if it's giving out a Blue Screen error.
If it still restarts in safe mode, shut the computer down and go to the BIOS.
From shutdown turn the computer on and start tapping F2 or Delete Key on your keyboard if both doesn't work check what key does your computer say to go to setup.
See wether if it will restart in the BIOS.
If it does, You may want to have the hardware parts of your computer checked.
If it doesn't my recommendation would be to reinstall yout operating system.
Hope you find these steps helpful!
Apr 30, 2011 | Intel Motherboard
D815EEA2 - No Display But Pc Running Just Try It Bios Update intel.com Site.If You problem Solution ? So Please Help Me................
Try shutdown computer using switch on tower. Restart in "safe mode". Window will pop up and click on "what is system restore", click on that. Another window will pop up, scroll down to "start safe mode", This will take a minute or two. A window will come up and click start or ok. The system will restore back, shut down and restart. Hope this helps.
Mar 22, 2011 | Intel Desktop Board D815EEA2 Universal...
I have an hp m9500t quad core. it runs fine for 2 to 3 hours then gives windows process error and shuts down with a bsod. i can shut it down and use it again the next day and "I am typing this message...
You need to provide the stop error code and the technical information that you are getting on the BSOD screen. Because the troubleshooting varies for different error codes. You can try doing a bios default and after that u can go to safe mode with networking and from there u can go to the hp website to find the latest update for the bios of the pc.
Feb 17, 2011 | HP Compaq Motherboard
Blue ecreen error, system shuts down
Hi.
Blue screen means that an exception handling memory or a different computer resource has ocurred.
Blue screen error often occurrs when the sytem is corrupt.
Usually it is possible to fix the problem reinstalling Windows operative system.
Before reinstalling Windows you can try starting the system in safe mode (try F8 on startup). If system starts in safe mode, do a system restore to a recent date before having the problem.
Windows can be reinstalled using either factory recovery disk or a generic Windows setup disk in conjunction with a valid Microsoft licence number.
In case reinstalling Windows does not fix the problem, even if there are more hardware faults that can cause the problem, the first culprit is usually RAM memory.
Try reinstalling the system first.
Aug 08, 2010 | Acer Computers & Internet
Problem with ASUS P5GD1 mobo
Is the cpu fan working, remove all the memory,but one stick, then try each stick you have. Then, When you get your post, enter safe mode, this does not use full video, so if you can, and it works in safe mode, it is probably your video, if not it is either
your power supply or another piece of hardware.
Unless you installed something on windows just before this problem.
Post back if you need more help, any code errors would be great to post.
Feb 05, 2010 | Computers & Internet
New motherboard put in my hp pavillion dv6262 in January when computer wasnt even 2 years old. Computer is trying to start up showing a black screen and within a few seconds shutting back down again. Is...
I have reviewed your problem and have the fallowing items for you to check and or try.
Try booting into safe mode and see if the same thing happens.
( F-8 )
Choose safe mode with network configuration installed.
If the unit runs without shutting down, it is a program conflict and not a hardware issue.
Run this safe mode start up, with no external devices connected.
Note... Remove any Flash Cards or USB devices, CD or DVD's .
If the unit runs without shutting down in safe mode, you may want to run a complete restoration of software.
Hope this helps.
Oct 23, 2009 | HP Computers & Internet
BSOD- STOP error message
most bios updates are found on the compaq website, they need to usually uncompress to a 3.5 floppy or they are auto-installing programs u get from the website, your issue however sounds to me more like a corrupted version of windows, did you try a fresh installation with the recovery cds or master disks?
Aug 12, 2008 | Intel Motherboard
Error message\system32\ntskrnl.exe.
you need to repair or repair your operating system. but first you need to purchase this windows xp in order for you to repair this. yes you have a corrupted file in your system. the cause of this is the improper shut down, or a virus that infected a system folder
Apr 29, 2008 | Syntax SV266M Motherboard
MSI MS-6368 Motherboard Logo
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
