Question about Vacuums
Vacuum Power Probelms.
Vacuum would not power off and now will not power on. I've read where people have a similar problem and take it in for repair but I am more interested into what specifically caused this problem. Thanks.
  • 1 more comment
  • tc031608 Mar 21, 2008
    Thanks. I was thinking the switch but then I wasn't sure if the problem was related to the power board that the switch cable connects to.
  • Anonymous May 01, 2008
    The on/off switch won't turn off. I have to unplug my vacuum to stop it. This has happened previously (2 times) and something I did (don't know what) made it start working again. This time I can't seem to get it to turn off no matter what I do.
  • simmica Sep 11, 2008
    r vaccume whenever we plugged there is no power no sign that it's start
    President:
  • 1,673 Answers
Sounds like a problem with a switch. They do go back, but if this is your problem, don't know without checking it.
Posted on Mar 20, 2008
Dc07
hi there.
see if this link helps you out.
How to Repair Dyson Vacuum Cleaners How to Service Dyson How to Fix Dyson
This could be a faulty cable or switch, but could also be a faulty motor.
or this one might help you.
My Dyson Won Turn On Hunker
if you need to read up some more try this link.
Dyson DC07 Bagless Upright Cyclonic Vacuum NO POWER Google Search
Jul 05, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt will not stay on
Those machines have the belts on them at production.
You can read about this
www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Change the belt! Good as New!
Good Luck
The Vac Dr.
Dec 21, 2012 | Hoover Elite Rewind Bagless Upright Vacuum...
We have had the power wires that run through the swivel elbow at the end of the main handle extensions and the power head break after being repaired two times. The new swivel elbow and wiring connection...
Have them replace at the Aerus Electrolux shop. Aerus uses a higher grade plastic (Lexan, read about it on the net) which should last the life of the the power nozzle and wands. The part and labor will have a 1 year warranty.
Nov 15, 2010 | Electrolux Epic 6500 Vacuum
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
No suction of the water from carpet after soap is applied
Hello :
1: A vacuum pulls air through the bag, then through the tube attachment and then through the base (with the spinning agitator brush).
2:Check for signs of suction. Remove the tube attachment from its cradle and, after turning on the vacuum, put your hand to the end of the tube. Is there any suction at all? If there is a little bit of suction then you may have a clogged air tube.
3:Check the vacuum bag. It may be very full. If it is then remove the bag and replace it with a new bag. Check the suction power again. Has the suction improved?
4:Check the tube attachment. Completely remove it from the vacuum. You usually have to twist and pull the tube attachment out of place at the point where it connects to the back of the vacuum. Check the suction power again. This time you place your hand on the vacuum right where the tube used to come out of the back of the vacuum. Has the suction improved?
5:If the suction power has improved then you probably have a clogged tube. Dog hair, people hair, leaves and more can get lodged in the tube slowly over time and then suddenly block the tube completely.
6:Clean the tube by first trying to shake the debris out of the tube. If this does not work then go outside and run a hose through the tube. Use a pressure nozzle if you have one. Run the hose through one end of the tube. Then run it through the other end. Repeat until the debris is disloged. Dry the tube and then reattach to the vacuum.
7:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
8:Check the air hose in the base of the vacuum. This hose is usually pretty short and you can see if there is any blockage. If you see blockage then try to remove it. You may need to reach into the hose with a tool (like a screw driver or something long).
9:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
10:If you made it to this step then you may have a problem with the motor on your vacuum. If this is the case then you will need to take the vacuum in to a repair shop.
Things you will need :
1 Philips screw driver
1 flat head screw driver
Warning :
# Always unplug electrical devices before you work on them.
# Never work on electrical devices around water or when you are wet.
I hope this will help .
please rate !
Apr 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Nov 08, 2009 | Dyson DC14 All floors Bagless Upright...
The Vacuum canister is working but the tip did not havesuction power. Should I change it? Where can I finf the repair shp in my vicinity. My area is Ravenna, Ohio 44266. My Vacuum cleaner is about 10...
try checking for blockages first, turn the foot of the vaccuum over and check the inlet tube, there may be a little flap that needs to be pulled forward for you to see if there is a blockage.
Dec 08, 2008 | Electrolux Vacuums
Ive got a miele revolution 5000 power plus and its just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=640910
Generic problem for all Vacuums
I’ve got a Miele revolution
Posted by rowler on Jun 02, 2008
I’ve got a Miele Revolution 5000 power plus and it’s just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any ideas?????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not familiar with the light system on the Miele Revolution 5000 Power Plus
But it has something to do with the electronic hose assm or the circuitry in the vacuum itself. I have listed the factory phone # listed below for your further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/ Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Princeton, NJ 08540
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Vacuums Logo
110 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
