Question about Waring Pro WC1000 Coffee Maker
It tripped the GFI circuit and now the water does not get hot
  • Anonymous May 13, 2008
    My WC1000 does not heat the water after about 8 mths. use. I have given vinegar cleanings - still no hot water.
    Problem Solver:
  • 11 Answers
A short condition has severed a conductor wire inside the coffee maker. Seems to be a common problem with coffee makers as the wires are in close proximity to heating devices.
Posted on Apr 07, 2009
The gfi trips every time I turn it on
Chances are while you have a 20amp circuit in your kitchen the gfi you are plugging into is rated at 15amps. First make sure your outlet is connected to a 20amp circuit breaker and then change out the gfi for a 20amp one. This coffee pot is more for commercial than residential usage, I had the same problem until I changed out the gfi plug.
Jun 03, 2010 | Waring Pro WC1000 Coffee Maker
We have a waring pro wc1000 coffee maker and it just started taking forever to brew a pot of coffee. How can we fix it?
If you've never done a decalcification, do one. A decalcification basically means that you're running vinegar and water through your coffee maker to get rid of calcium build up, which can cause your coffee maker to run very slowly, or not at all.
You always want to do a "1/3 white vineger to 2/3 water" solution--meaning that if you have a 10 cup coffee maker, you want to fill it 1/3 of the way up with vinegar (3 cups), the rest with water. If you have a 12 cup coffee maker, you want to do 4 cups of vinegar, fill it the rest with water. And yes, it DOES have to be white vinegar--the other vinegar types don't do anything for calcium ;)
You basically just brew the vinegar/water though your coffee maker, and you might have to do it 2-3 times before it will be completely fixed--most companies recommend that you run the vinegar/water through your coffee maker once ever 1 to 2 months to prevent things like this from happening, so if it's already happening, you may have to do it more.
And always remember--after you brew a pot of vinegar/water through your coffee maker, brew a regular pot of plain water through it afterwards, or your coffee will taste like vinegar! lol
If all else fails, you can always contact Waring customer support - their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 26, 2009 | Waring Pro WC1000 Coffee Maker
I lost the instructions for using the Waring WC1000 coffee maker-how do I brew a pot of coffee?
JUST LOOK UP ONLINE THE MODEL NUMBER OR CONTACT CUSTOMER SERVICE FOR WARING AT http://www.waringproducts.com/
Aug 22, 2009 | Waring Pro WC1000 Coffee Maker
I have a waring pro 12 cup coffee maker but no manuel.
Most of them will make any amount of water you put in.But I would remen 2 to 4 cups.
Mar 13, 2009 | Waring Pro WC1000 Coffee Maker
GFI
Hello Joesal,
A GFI receptacle senses and imbalance between the hot ( line voltage) feed and ground. There should be no current sensed on the ground. This protection feature will disable the line voltage in milliseconds if it sense current passing thru to ground. The intent is to sense current flow to ground and in the event that you are that path ( meaning current is flowing thru you as a ground)..it disables that line voltage in milliseconds to keep you from being electrocuted. You have either a bad GFI receptacle or there is leakage current getting thru to ground. In either case, its a good idea to determine which is the problem.. I suggest you try your coffee maker on another GFI receptacle in your home ( perhaps in the bathroom or basement) to verify the coffee maker isn't malfunctioning. If it is,, then you may want to discard it or if you are elecrically handy, repair it,... Do not compromise you or your familys safety with these things.. Be careful and good luck..
In addition,if you do run the coffee maker off an extension cord, make sure it is properly sized for the current that your coffee maker requires.. I wouldn't use any extension cord less than 14 gauge ( #14 )
Good Luck..
Oct 01, 2008 | Waring Pro WC1000 Coffee Maker
Waring pro wc1000
Try plugging it into another GFI outlet. If it still trips, it's a problem with the coffee maker wiring and is cheaper to replace it than fit it.
Aug 25, 2008 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
WC1000 GFI
You're not alone.  Same problem here.  Breakaway power cord on my Waring deep frier burnt to a crisp.  Don't known about you, but I'll never buy Waring products again.
Oct 03, 2007 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000 Coffee Maker Logo
Top Waring Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
