Question about D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter
Won't recognize my wireless card, reads it as pcmcia mtd-00002 (Memory card?) dell laptop inspiron 2600 windows xp, removed harddrive, reinstalled and then this happened.
  • bjksr Mar 16, 2008
    did install properly, did not work, worked before i took out the hard drive and also replaced cd-rom with a dell burner cd-rom. wish it were that easy. upgraded smart card reader drivers, trust me have tried everything, read on web that i had to turn off soundblaster in bios, but not an option in this bios, just will not recognize the card, it is getting power but thinks it is a pcmcia mtd-0002.
    Sergeant:
    Champion:
  • 256 Answers
Hi
Install driver properly it will work. dell.com
Thanks
Posted on Mar 16, 2008
Cant find where to install a wireless card internally to my dell inspiron 2600
You can't install any cards internally as there isn't any room inside. If you want to add wireless capability you'll need a USB wireless adapter which you just plug in to one of the USB ports. This computer also has PCMCIA (card-bus) slots, but that's older technology. USB adapters are much easier to find.
Jul 31, 2011 | Dell Inspiron 2600 Notebook
Unable to wirelessly connect anymore
Click on the network icon in the task bar. Show the networks available and right click on the wireless network if it shows up. Try the 'repair' network selection.
You can also 'remove' the wireless device and re-install it. If you use the command: "ipconfig /all" it will display all the connections and their settings. Normally windows will use the auto config 192.168.xx.xx series of IP addresses if it cannot find a DHCP server to issue it an address. That should show up in the ipconfig output in the wireless network device section.
If the ipconfig does not show the wireless device, try the uninstall/re-install tactic.
If this is a PC-card [PCMCIA] that you can physically remove, power down, remove the device, power back up. Power down again, install the card, power up. Windows might then 're-find' the device and reinstall all the necessary drivers.
tom
Jan 18, 2010 | Dell Inspiron 2200 Notebook
What type wireless card do I need for inspiron 2200 laptop
What you need is a Wireless MiniPCI Card, check this out >>>>>>>
http://www.parts4nb.com/catalogue/product/dell-inspirion-2200-wireless-minipci-card-other
Regards.
Aug 06, 2009 | Dell Inspiron 2200 Notebook
Wireless enable problem
Check under Device Manager first. That's under Network Adapters. If you see a thing called Network Controller under Other devices, the driver for your wireless card has not been installed. Simply reinstall it by right-click > Update Driver. But if you see your wireless card there with yellow caution sign, the driver needs to be reinstalled. With red X, that mean its disabled, right-click it and Enable. If no wireless card under device manager, your built-in wireless card is busted, you need to buy a separate notebook adapter. Good Luck!
Mar 24, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Trouble with Secure Digital I/O slot on a dell laptop inspiron
go to google and look for SD card driver for xp, after you load the driver you will be fine.
Mar 24, 2009 | Dell Inspiron 9300 PC Notebook
Can't connect to internet through wireless
Go to a working computer (beg borrow or steal) and download the drivers for your model laptop from the DELL WEB site (suggest you insert your Service Tag to get the correct drivers for your model laptop), copy it to a CD or USB memory stick and then install them on your computer.
Don't forget to activate your XP license and also install SP3 (Service Pack 3 it's approx. 350Mb in size).
Dec 28, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Laptop Won't Boot Up
The laptop won’t POST after removing the memory? Sounds like the memory module (s) need to be reseated again. Removing memory will not reset the laptop. If you want to install a clean Windows XP load, you need to boot from the Windows CD and format the hard drive.
Fell free to contact me if you need futher assistance.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell inspiron laptop doesn't recognize wireless adapter after Windows reinstall
If you are able to, simply
1. Go online via the ethernet plug in port at a friend's place, or if you flash a smile and ask nicely at a place with wi-fi, they will have a hardline plugin as well. This is my first suggestion.
2. You can use a jump drive and go to (my computer is a dell) dell's website and check their drivers page, you can simply search it on their main page along with their support page. Then just look for the appropriate wireless drivers, and save them onto your jump drive, then run them on your computer and bada-bing bada-boom! you should be up and going, I ran into this everytime I reinstalled my OS on my laptop and my desktop :P sux that it isn't more automatic, but if you keep the drivers on a disk or your jump drive you can use them again.
good luck!
Jul 15, 2008 | Dell Inspiron E1505 Notebook
Pcmcia mtd-00002
Please use this webpage to download the newest uptodate drivers from Dlink
http://support.dlink.com/downloads/
If that doesnt solve the problem, let me know.
Mar 16, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter Logo
271 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
