SOURCE: garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
SOURCE: cannot find my map data anymore
Have you checked the wrench menu, map info, the preinstalled map should have a check mark, if not tap on the check box, it should now show a detailed map screen when you go back to the main menu and select show map.
SOURCE: "No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
SOURCE: garmin nuvi 660 lost map data
Hi Bruce. The same thing happened to me . I called customer support
1-800-800-1020 and they were able to link ino my computer, go through it and into my GPS. Hopefully this will work for you!!!
Tom
