Question about SanDisk Sansa e270 MP3 Player
Can't download playlists to Sansa e270
OK, I followed the video instructions for WMP 11 on Vista (from Sandisk website), and also tried dragging and dropping into playlist file on the e270, but my Gym Mix playlist won't go.
My christmas playlist and my KC and the Sunshine Band playlist will but not my Gym Mix.
    Problem Solver:
  • 11 Answers
Did you try dragging the songs individually??
Posted on Mar 16, 2008
SOURCE:
I can not resync my sansa e270 when i plug it into the computer, i use rhapsody and never had this problem before
Hi, theres 2 ways usually to sync with sansa.
usually wen u plug it into the usb cord, u shud be able to open a folder and put musik through that.
My computers. than go to Sansa
or WMP depending on ur version
go to Synchronizing or Copy to CD or DEVICE.
there should be syncing button under the music list depending on the version.
but i stick to open my computer and the Sansa folder.
IF NOT THAN DO THIS..
Go to ur Sansa in the USB option change it to MSC than follow these instructions
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the drive for your Sansa.
3. click on Tools choose File Option, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
Good luck.
Mar 12, 2011 | SanDisk Sansa e270 MP3 Player
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
May 01, 2010 | Coby MP-C653 MP3 Player
Downloading music to my MP3 player, how do I do it. I have the music on my computer and I move to the MP3 player but when I disconnect it does not display on my MP3 player
For transfers to Sansa Clip see page 11 of the pdf manual [page 9]:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When using the drag and drop method in Windows
music has to be dropped in the Music folder of the player.
Using Windows Media Player 11:
In Library or Sync mode:
1. Create a playlist e.g. "MyPlaylist"
2. Put music in the playlist
3. Save the playlist
In Sync mode and the player having connection:
4. Move the playlist e.g. "MyPlaylist" under / to the device
5. Start synchronizing with Start Sync
6. Wait until al files have been transferred:
a message appears when you can disconnect .
When you need more help just post a comment.
Sep 23, 2009 | SanDisk Sansa Clip MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
How to operate sansa and creating data base
Sansa support for e200 series:
http://www.sansa.com/support/sansa_e200/faqs
user manual e200
For making videos appropriate for your player use:
sansa media converter
When a total reinstall for the player is required perform:
sansa firmware updater
Remember: running a firmware update will erase all data on the player !
For transferring files from the computer towards the player you can use
Windows Media Player 11. A short guide in how to make transfers:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
How can i get videos on my mp4
There's an online manual for COBY mp-c7095 in pdf format:
http://www.cobyusa.com/files/manuals/MPC7095_MN.pdf
1. Use the video conversion software from the CD for adjusting
video to correct size before transferring to the player.
2. Check the system requirements for video conversion on page 34.
The conversion software in zip format can be downloaded with this link:
http://www.cobyusa.com/files/software/MTVVideoConverter_Ver1.12.11.zip
Once video is converted u could use Windows Media Player 11 for
transfers. A short guide on WMP11 for putting files onto the device:
Sep 12, 2009 | Audio Players & Recorders
RE:WINDOWS MEDIA PLAYER 11 IN VISTA
Does your player show up as being connected in WMP11
Sync mode ? If not, a firmware installation for the player is needed.
If yes, did you perform doing next actions ?
Sep 04, 2009 | SanDisk Sansa e250 MP3 Player
I dont have a disk or manuel for my sandisk sansa m240 how can i download music to it? I have the usb cord tho.
Follow these steps to drag-and-drop music files to your Sansa player:
1. Connect your Sansa player to your computer.
2. Open Windows Explorer.
3. Double-click on your Sansa player.
4. Double-click Internal Memory if you are using WMP 11 or double-click
Media if you are using WMP 10.
5. Drag and drop music files from your computer to the Sansa player’s MUSIC
folder.
Dec 10, 2008 | SanDisk Sansa m240 MP3 Player
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
Sync problems ...
The instructions with pictures are on pp. 13-19 of the user's manual:
Loading Music
You can transfer music from your computer to the Sansa player using the dragand-
drop method or using music managing software like Windows Media Player.
Drag and Drop
Follow these steps to drag-and-drop music to your Sansa e200 player:
1. Connect your Sansa e200 player to your computer.
2. Select Open device to view files using Windows Explorer on
initial connection.
3. Double-click on Sansa device.
4. Double-click on the MUSIC folder.
5. Drag and drop music files from your computer to My
Computer\Sansa e200\...\MUSIC.
Before you can create playlist and transfer (or synchronize) them to your
Sansa player, you need to show Windows Media Player where your songs are
located.
Adding Music Files to Library…
1. To add music files to WMP 11’s library, please follow these steps:
2. Click the arrow below the Library tab.
Loading Content 14
3. Make sure Music is selected then click Add to Library…
4. In the Add to Library dialog box, click one of the following options
then click OK.
- My personal folders:
Use this option to monitor the digital media files stored in your
personal Music, Pictures, and Videos folders, as well as any files
stored in the public Music, Pictures, and Video folders that everyone
who uses your computer has access to.
- My folders and those of others that I can access:
personal Music, Pictures, and Videos folders, the files stored in the
public Music, Pictures, and Video folders, as well as the files stored
Loading Content 15
in the personal Music, Pictures, and Videos folders that belong to
other users on your computer.
Mar 12, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
93 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
