Question about Apple iPhone Smartphone
Recovery mode hi i have an i phone that got warm then shut down after awhile went to recovery mode when connected to pc i tunes says in rec mode and to restore im running unlocked 113 version im worried if i do restore il lock it or brick it i saw thread on ibrickr if phone goes red or green etc tried this but it didnt give any command would appreciate any advice on this thanks
  • 32 Answers
Goto www.hackthatphone.com follow the tuts there. no easy answer..just a small bit of reading, you will have to unlock the phone once you restore..but if you follow the tuts you should have no hassle
Posted on Mar 17, 2008
SOURCE:
My iphone wont start i was working with it till i went to lunch i put it in to my pocket then wen i toke it out dead it wont start i tryed the home and power everything nowthing i connect it to pc itunes...
Disconnect the cable.
Hold down the home and power button for 15+ seconds.
When the phone turns off, wait a minute then power it back on with the top button.
If it is still stuck in recovery mode, open itunes, connect the phone, and follow the prompts after it says it detected an iphone in recovery mode.
May 06, 2011 | Apple iPhone Smartphone
Hi when i reset my i phone 3 5 it only shows apple sign and when connected to comp it doesnot show i tunes
You will probably need to reboot into recovery mode and restore your phone. To get into recovery mode, make sure your phone is connected to you computer via usb cable, then you need to hold down the sleep button and the home button down at the same time for 10 seconds then release the sleep button. Continue holding the home button down until iTunes detects a phone in recovery mode, once it's in recovery mode you can press the restore from within iTunes.
Mar 02, 2011 | Apple iPhone 3G Black Smartphone
My iphone was charged up then it went blank then wen i put it oo the charger its saying connect to itunes
You seem to have either entered restore or dfu mode your going to have to restore your phone
Feb 28, 2011 | Apple iPhone Smartphone
IPHONE APPLE 2G BOOTING PBLM
Looks like the software image you downloaded from Apple could be corrupted?
Try launching I Tunes on PC without I phone connected. Then make sure I Phone is switched off. Now hold down the home key (square at bottom of screen) Whilst still holding home key plug in your I Phone usb lead. I Tunes should identify you I Phone after few seconds and prompt " detected I Phone in recovery mode" (or similar) it should then prompt 'yes' or 'no' to do recovery. Select yes and let it start. This should resolve this issue as it did on my 3G version.
If still no luck search FAQ's section on www.apple.com
Hope that works/helps?
Mar 21, 2010 | Apple iPhone 3G
My iphone is frozen at the apple logo screen and wont power down or sync with itunes. How do I fix this?
Have you tried holding the power button and the home key together. Hold until unit reboots and once apple logo appears, release both buttons. If this doesnt work try this below.
Oct 14, 2009 | Apple iPhone 3G
After restorin im nt bein able to acces iphone only emergency cal
try holding down just the sleep/wake button" till slide to power off appears",
then leave phone powered OFF.."
then hold down the home screen button and plug into iTunes and wait for iTunes to say:
iTunes has detected an iPhone in recovery mode......
then let off the button set phone down and hit ok in iTunes then restore to factory..
this is called "Forced Recovery Mode'' give it a shot, it should work
Sep 30, 2009 | Apple iPhone Smartphone
My itouch wont go into recovery mode how do i restore with mac osx
it took me awhile to get into recovery mode but what i did was hold power and home button down then when it resets and the apple logo come up let go of the power button keep holding the home button and it went into recovery mode.
Jul 21, 2008 | Apple iPod touch
My sansa e250R not working
Hi try this for me and let me know if you can put it in recovery mode if it does go into recovery mode dont do anything just let me know then ill tell you what you need to do next ok
1. with it switched off put key lock on
2. hold down rec button on left hand side
3. whilst still holding rec switch it on still holding down rec
4 it should now say recovery mode
let me know when you get this far ok
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Bad Song caused screen to go blank!
move the button HOLD switch ON,to see orange.Hold down REC button and with the REc button holding down,connect the player to the computer.this is Recovery Mode.If your computer recougnize your plaer like 16mbFormat,everything is ok,in this case do as i say in the following text.(if it doesn't been recougnized by the computer...i can't help you)Go to START-PROGRAMS-ACCESORIES-NOTEPAD.IN the new text notepad,do not write anything,go to file-save as.In the box "Save as type" select "all files" and in the box "file name" write :sansa.fmt
Save the notepad file on desktop and copy it in your "16mbFormat"sansa player in recovery mode.16mbFormat is the name of your player in recovery mode wich you will find in My computer.Do not copy anything at there.like music or other files.after that disconect your player and enjoy.this is FORMAT in Recovery MOde.
Feb 14, 2008 | SanDisk Sansa e250 MP3 Player
Apple iPhone Smartphone Logo
47 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
