Question about Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool gold electric range control panel blinks w/all lights powers oven off
Heres's my problem; I have an electric range glass top whirpool gold model# gr465lxls, when i first plugged it in, all was working fine, about 5 mins into turning on oven, the digital display/contol panel, falshed w/all lights on, then off then clock came back on showinbg time and pf. the burners will continue functioning fine, but oven powers off, and the lights on the digital display continue to go nuts, flasing on/off/back on. we had elctrician come to make sure outlet is putting out correct voltage/amps, connections, ect., all on that end checked out. can you help? thanks!! Amy
  • zoohouse Mar 17, 2008
    Thanks for trying, I wish it was covered under warranty, but just out of warranty, I already called whirpool :(. We moved it from another home, where it worked fine. Since my last post, however, it has been on without issue for about 8 hours, but problem does seem to be intermittent, so I expect it to freak out any minute again. Thanks again for the help, if you know anything further, let me know!
  • Anonymous Mar 15, 2014
    modelLRE30757ST contol panel on top of stove of that operated the clock has almost constant light static sounds since last night. Turned off circut breaker (40amps) and reset it; still continues.
I had the same problem, and this suggestion (for a similar problem) worked for me. It reset the controls when they were locked up. Just turn off the circuit breaker for five minutes, then turn it back on. Good luck!
http://www.fixya.com/support/t1098180-whirlpool_gold_electric_range
Posted on Oct 22, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
You say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
Posted on Mar 17, 2008
SOURCE:
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Do I have to replace the control panel on the oven if it isn't lit?
Without a full schematic, and an understanding of electrical wiring, you have no idea if the internal 120 vac light is even on the same circuit as the control panel. Electric ranges are generally powered by 220vac, which means that both 120 lines are run through the unit.
you could have full power to the appliance bulb and have a blown fuse to the control panel, how much of the range actually functions at the moment would be important information to share.
Mar 04, 2015 | Whirlpool Gold 30 in. Double Electric Wall...
Wire burning smell whirlpool range. Happens when oven or top are turned on. Smoke come out under control panel.
Had the same problem with my Whirpool range. Took off the rear panel and carefully plugged in and turned on the top oven. One of the terminals on the part labeled as 'Switch, Hi-limit' started to spark, glow and emit smoke. This part had 2 blue wires running to it. One came off of the top element in the top oven and the other fed back into the black plug on the control panel. Part in quests is held on with a single screw and has a part no. of 7403P993-60
Oct 30, 2011 | Whirlpool GR673LXSS - Stainless Steel...
Cracked glass top what is the price of a new one?
Sears.com has the glass top for $353.58. That is for the part only, They charge around 129.00 to 159.00 to replace it for you. Part + Labor +tax. Hope that helps
Sep 02, 2011 | Whirlpool GR465LXLS Electric Kitchen Range
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Jan 20, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool GR465LXLS Electric Kitchen Range Logo
404 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
