Problem for Washing Machines
Generic problem for all Washing Machines
GE WBVH6240FWW pause/drain problem
Washer pauses at 30 and 8 minutes left in cycle and does not spin completely. Items are soaked at end of cycle. Any advice is appreciated.
Same Problem
Mar 25, 2009
-   I had a similar problem that it stopped before the cycle ended. It left one minute and at times it would not start at all. I unplugged the machine for a few hours and it would eventually start again. The repariman came and he found that the large grey rubber gasket had a tear on it. He replaced it and said water was shorting the electrical wiring. Seems to be working fine so far. Check your seals for starters. -   Guest Mar 10, 2009
-   Me too... the darn thing used to work just fine. We haven't even owned it a year. -   Guest Jan 26, 2009
-   We have been dealing with this for weeks, with the problem getting gradually worse and worse. Rinse and spin worked for a while, then we had to add one or two drain and spins. Now, the washer will simply not complete a cycle. I wonder if it is a programming glitch on the mother board? -
masterfool Dec 07, 2008
-   same problem....how to get to the filter and repair the pump?
-   Guest Oct 16, 2008
-   Yes, very annoying as adds much time to do one load of laundry. You'd expect wash to be finished when you go downstairs, but multiple trips down just to hit the pause/start button again. Tried the rinse/spin cycle, but sometimes this takes 30 min (not the 15 as timer indicates). Just a pain!
bicyclejim
Best Solution
posted on Nov 24, 2009
Rank: Apprentice
Rating: 100%, 1 votes
Need a little extra money? Clothes coming out soaking wet and not rinsing properly? I just read the posts on this issue and cleaned my washer's drain filter. I'm now $4.98 richer. I also found three pencils, kids of course, one class ring, key chain and a pair of finger nail clippers. I won't mention the other nasty stuck in the filter.
Don't forget to have something to catch the water when you loosen the drain filter. I used a sauce pan.
Good as new and no repair bill. I'm going to Taco Bell for lunch with my $4.98.
Was this helpful?1 person thought this was helpful
Solution #2
posted on May 09, 2009
Rank: Apprentice
Rating: 100%, 9 votes
I had the same problem for months. Load would pause all the time and items would be soaked. Today it wouldn't do anything and I found out that it was a drainage problem. I called the warranty department and they scheduled a service but warned me that if the problem was caused by debris in the sytem, I would be charged for it. So, I took the job on and finished with like new results after about 4 hours of work. First the pump filter was nasty(batteries, coins, a wrench, hair,etc.), so I emptied and rinsed. Unplug machine. Take off lower front panel (3 screws) and the turn the pump cleanout knob counterclockwise about 2 turns. Have something ready to catch water. Put back in and test machine. If that doesn't work, you will have to clean your pump. Repeat the same drainage process with pump cleanout knob, take hoses off from pump (to the right side of pump cleanout tube), disconnect wiring, remove both screws holding the cleanout tube and pump to the frame and remove assembly out of washer. Remove the 3 screws on the back of pump. Take a flat screwdriver and pry the impeller from the body of the pump(pry carefully because you don't want to mess up the o-ring). Once you have the impeller out, clean impeller and inside of pump casing.(Don't get the electical portion wet!). Put everything back together and test. That is everything I had to do. It sounds hard but it really isn't. Remember to disconnect power from the machine before working on it. You don't want water from the pump cleanout spraying all over the place, the machine has an internal ground and you may become one if your not careful. Our machine is working awesome, my wife is not yelling no more, and I really hope this helps somebody out there. Good luck.
Was this helpful?9 people thought this was helpful
Solution #3
posted on Mar 13, 2009
Rank: Apprentice
Rating: 100%, 4 votes
It is the pump filter. I removed the three screws from the lower front panel and directly behind is the access port for the filter. Keep in mind that there will likely be a lot of washer water behind this clog; one bucket full in my case (I know this because I had to mop it off the floor...sigh). After cleaning, the machine started draining as good as new. No more indefinite pauses.
Was this helpful?4 people thought this was helpful
Solution #4
posted on Nov 26, 2009
Rank: Apprentice
Rating: 0%, 0 votes
WOW..... That was the easiest repair that I have ever had to do.... We were having the same problems with the washer pausing and have wet clothes when the washer got done. (if it would after prolonged time). The filter was gloged with all kinds of stuff.. But I only made 67 cents.... The screws are on the bottom front down at floor level... you don't even have to move the washer to clean the filter... Had it done in about 15 min. I want to thank everybody above with the info..
B.A. Murray Beaverton, OR
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
whirlpool ultimate care ii washer LSQ9110PW2
Westinghouse Washers and dryers
Wash spin cycle very noisy
I have a Maytag Performa washer (model # 2200AWW). Last night it quit working with a full load of...
(More)
I have a Maytag Performa washer (model # 2200AWW). Last night it quit working with a full load of clothes and water in it. Immediately afterward we noticed a electrical burning smell coming from the washer. Is my washer toast?
Water is leaking from bottom of machine Water is collecting in liquid bleach dispenser
7 Other Users Have The Same Problem - Continued
Comment by sidsmommy3, posted on May 11, 2008
I had the same problem. Took the bottom off and cleaned out the filter and my husband took the pump apart and repaired it. I am keeping my fingers crossed now!
Comment by Guest, posted on Apr 05, 2008
If I perform a speed wash it cycles fine, and all other washes the machine will pause and unlock the door and you must hit the pause/lock button to resume the cycle. Even after this the clothes will not be completely spun out.
