Question about Mitsubishi VS-60707 60" Rear Projection Television
Front screen I have pulled on front screen to remove as to get to spider webs out from inside. How does this come off or click back into place. Have it half pulled off.
You have to remove the speaker cover under the screen and controls. It says Mitsubishi on it. The speaker cover pulls off. There are some screws under the control panel that have to be taken out. Then follow the 2 sets of wires from the control panel and unplug them. You can then lift the screen up and it should come off.
dougtanner7@msn.com
Posted on Mar 22, 2008
HI I HAVE A SPIDER WEB IN MY TV HOW CAN I GET RID OF IT . IT REALLY BOTHERS ME WHEN I WATCH TV BECAUSE I CAN SEE IT
try to open the back of your tv but be sure to unplug it then clean the projector lens using a dry cloth cotton.
Oct 15, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
51" Philips Projection Wide Screen. Want to know
Almost all the Philips projection sets have a large black plastic shroud on the top half of the back of the set----it can be removed--most of these sets use torks type screws (star shaped).
With the upper part on the back removed you will find the mirror is suspended---do not try to clean it--it is film like handy wrap and will not need cleaning.
I use a swiffer type duster to reach inside the set to remove any spider webs etc, If dead insects or dirt inside the screen use a very soft cloth with water (just dampen the cloth slightly)
Usually you are seeing spider or cob webs and the duster will get them all--DO NOT APPLY FORCE IF YOU WIPE THE INSIDE OF THE SCREEN AS IT IS EASY TO SCRATCH IT!
If this information helped you, rate this solution as I do this here for free.
If you have questions make a comment here and I will do my best to answer them.
REGARDS, SD TECH
Aug 18, 2010 | Philips Magnavox 27MS343S 27" TV
Cleaning webs from inside screen
There are two ways to do this---the hard way which is to remove the entire front screen OR
What I do is (with the set unplugged) remove the back cover of the set; you should see the three large black lens.
Most of these sets there will be enough room to get a swiffer duster up inside to gently catch and remove all the spider webs. If there is not enough room let me know and I will tell you how to remove the front screen.
Also---if you can see those large black lens---clean the dust off of them with a lens cloth or paper towel with glass cleaner sprayed on the towel.
If you can reach the webs from the back do not exert pressure when you wipe the inside of the screens---easy to scratch them.
If you have questions let me know BEFORE you attempt this.
If this helped or told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Toshiba 57H82 57" Rear Projection...
How to clean the screen
Start by taking off the front bottom cover, usually they have screws way at the bottom one on each corner, then uncrew the screen usually there is 3 screws at bottom of screen pull up and out on the screen the screen has small screws in the inside all the way around take them off once you reached screen take it out and split it in half clean it with dry rag then put everything back together exactly the way u took it off before you screw the screen back clean the projectors with dry rag and the mirror with windex or any glass cleaning product.
Jan 31, 2010 | RCA P46812BL 46" Rear Projection...
It has a spider web inside the screen and I need to know how to clean it because it is directly in the center of the screen
The best way to get at it is through removal of the front screen. Start by removing the front speaker grill-should just pull off (snap fitted). Then remove the front control panel (4screws). Next remove 4 screws from bottom of front of screen- the screen should ten just pull off -also snap fit- Make sure the set is unplugged before you begin- Once the screen is off you can also clean the lenses and the mirror (if glass) use a soft damp cloth.
Sep 26, 2009 | Toshiba 50H82 50" Rear Projection...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Spider web behind front of screen
Take the front speaker grill, and ther will be a few screws on the bottom of the screen. Remove those and lift the screen up and out.
Feb 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Spider web inside tv
You need to open and clean it carefully.
  1. remove the back bottom panel
  2. Remove the top back panel (carefully the mirror is on it)
  3. Clean the mirror and the lenses (on the mirror don't use products with ammoniac) "a good tip is to use same staff to clean photographic cameras"
  4. Place back the top rear panel
  5. place back the bottom rear panel
Nov 09, 2008 | Samsung PCH521R 52" Rear Projection...
Trying To Remove Screen
I have a panasonic 53 inch and have had the same problem on numerous occasions. I removed the backing of the television, stuck my vaccuum cleaner hose inside the tv and sucked out the spider and the web.
Apr 29, 2007 | Toshiba 65H81 65" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
