Would like to set clock on radio model number KD_SX650
  • 667 Answers
Here is a link for the manual. Page 19 is setting the clock. Hope this helps. http://resources.jvc.com/Resources/00/01/00/FSUN3103-631.pdf
Posted on Mar 16, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 28, 2008
    Dear deer, just checking to see if that manual I provided the link for helped you get your clock straightened out. If it did would you mind please rating this solution a 4 for fixed ya. ( can be found to the right of my solution post date. Just click on the fourth diamond. ) Thanks much.
I installed my JVC KD-SX650 and it works but when i turn my truck off it loses the radio station and clock settings, what could be the problem?
There should be a yellow "accessories" wire that controls the memory to the radio. If it is not properly hooked up, the radio will reset every time you turn off the ignition.
NOTE: It might be a different color than yellow, but this is the most common
Jul 13, 2010 | Car Audio & Video
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Jul 13, 2010 | JVC KD-SX650 CD Player
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Need to reset the clock on my JVC KD-SX650
Does this unit have RDS on it? if so switch it on and it should set your clock for you
Feb 03, 2010 | JVC KD-SX650 CD Player
Clock setting
Hold the SEL button down for more than 3 seconds. A sub menu appears. Use the track select arrow key to select the hours, rotate the volume knob to correct hour. Press track select key to select minutes, rotate volume to appropriate minute. press select again to finish. If this doesn't help, go to jvc.com, then go to support, then user manuals, enter model number. You can dowload the entire manual for free.
Good luck
Oct 25, 2008 | JVC KD-G210 CD Player
Change Time
Setting the minutes involves the same steps as setting the hours. You press and hold the "Select" button for a few seconds until the screen reads: "Clock H", "Clock M", "SCM Link", "Level", "Area" or "Line In". To set the minutes, push the "Track Up/Track Down" button until "Clock M" is highlighted on the screen. Once "Clock M" is on the screen, you turn the volume up or down to set the minutes. Once the hours and minutes are set, hit the "Select" button again and the clock will start. Hope this helps...
Sep 03, 2008 | JVC KD-SX650 CD Player
KD sx980
http://resources.jvc.com/Resources/00/00/97/49690ien.pdf
try here
Jun 23, 2008 | JVC KD-SX650 CD Player
HOW TO SET CLOCK
I NEED INFO ON HOW TO SET MY CLOCK ON MY JVC, MP3, KD-AR300. SPILLED COFFEE ON INSTRUCTION SHEET...........BUMMER.................:>((((((
NEED YOUR HELP ASAP PLEASE...............
THANK YOU VERYMUCH grandmangrandpa34yahoo.com
Apr 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
My JVC KD-SX650 WILL NOT POWER UP/JUST DOES NOT WORK?
hola nesesito la ficha q se conecta atras del estereo es para adaptarle un mp3. grasias
Oct 28, 2007 | JVC KD-SX650 CD Player
My JVC KD-SX650
get a good service manual for your car that shows the wiring for the stereo plug. match up the wires to your JVC's wires (solder tie wire-to-wire behind the car's connector)
May 26, 2007 | JVC KD-SX650 CD Player
 Grubhead
Grubhead
