GE Washing Machine
My problem is after the wash cycle is over the machine will not go to rince unless I turn the knob to rinse after that I have manually put it on spin only to finish the load. My model number is WHRE5260E1WW
  • daviesk123 Jun 24, 2008
    WBSR3140D5W washer will not automatically advance past the drain cycle (at all settings, gentle, normal, heavy duty) unless dial is manually advanced to the spin cycle. Will advance if machine is shaken (tipped back an inch and allowed to drop forward. If htis is the lid safety switch, how is it adjustible?
  • David Nathans
    David Nathans Apr 15, 2015
    same
    President:
  • 778 Answers
Saragary,
It sounds to me like the safety switch for the washer lid is faulty or just out of adjustment (you'll find an arm sticking out of the lid that corresponds to a similarly shaped but larger hole in the jam of the lid and that is where the switch actuator should reside).
Or, your timer might be at fault, since it completes cycles once you manually advance to the next one.
Eliminate the safety switch as the possible fault before moving on to the timer itself, as the timer is more costly.
Good luck.
Posted on Mar 16, 2008
My eurolux dw2112p/1 gets stuck halfway in rince cycle
replace the timer: a tiny gear that is driven by the timer mpotor has broken teeth at that time point
Feb 04, 2013 | Washing Machines
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
Washing machine will fill up with water for the rinse cycle and then it just shuts off.
if you dont have a soak fascility, then your board is the issue. There is no interlock during the rince cycle to inhibit the machine from running when full. Funny enough, when i find boards have gone faulty, it is often on the rince cycle.(various other brands).
Sep 15, 2009 | Kenmore Washing Machines
My Indesit Washer/Dryer repeatedly (but not always) gets stuck on the initial water collection part of the wash cycle. It makes a sound like water is filling (or draining) into the machine, there is water...
Pressure switch is likely clogged/full of sediment.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Washing Machines
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Washing Machines Logo
    171 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
