Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
Setting passwords on dell truemobile wireless router
Hi i dont have any passwords set and feel sure someone is using my internet- does anyone know how i can set a password for my pc and the two laptops using the wireless router? many thanks
  • 1 more comment
  • stickytoffee Jul 20, 2008
    Can someone walk me thorough how i enable wireless security?
  • Anonymous May 11, 2010
    Setting a password on your computers themselves only helps if they are physically in your house trying to type on your keyboard. I think what you want to do is enable WAP/WEP on your router. List your brand and model name/number and I'll see if I can't walk you through the process.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    do you have the manual for your router?
    Scholar:
  • 89 Answers
Hello, The default address for the dell truemobile 1184 is 192.168.2.1 If you have changed it and forgot, unplug the router (elec) for 5 seconds. This will reset it to default. The default SSID is "wireless". If a user ID and/or password is asked for enter "admin". Here you can change settings, enable broadcast, change SSID, enable WEP or WPA. Hope this helps.
Posted on Mar 17, 2008
SOURCE:
Where is the wps button
some routers dont have wps button but if you need to reset router To restart the Dell TrueMobile 2300 Wireless Broadband Router, unplug the power connector and plug it back in.
To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Jan 06, 2013 | Dell TrueMobile 2300 Wireless Broadband...
I have wireless internet... but the internet only works when i have the cable in.. and when i take it out.. the connectin is gone... pluse when i go to conect to network i dont see my ip address.
For that you need to enable DHCP on router also enable wireless on router. You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 13, 2011 | Dell TrueMobile 2300 Wireless Broadband...
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
I have a TrueMobile 2300 router and my security code is not working. How can I change it?
The only way to reset the password if you can't remember the old one is to reset the device. To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Then navigate to the router through your browser and Type the following as your username:
admin
Type the following as your password:
admin
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Advanced Settings tab.
Click the Administration Settings button on the left side of the page.
Put a check in the box to the left of the Change Your Password setting under the section of the page titled Password Settings.
Type the password that you want to use in the New Password field.
Retype your password in the Retype Password field.
Click the Submit button.
Another window appears stating You have successfully submitted the settings to this device!
Click the Save and Restart button.
Your new password will be saved into the router settings.
This will however wipe all your settings!
Jan 05, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Cant change password and i dont have cd
Taken from another location.
Most routers use "admin" as the user name and "password" as the password.
(No quotes of course) Make sure the caps lock key is off.
If that doesn't work, try resetting it by holding in the reset button on the
back for 10 seconds (if it has one - I'm not familiar with that router).
Aug 21, 2009 | Dell TrueMobile 2300 Router (000001)
Wireless security
the WEP password is located on the label on the botom of your router. The WEP password prevents unotherize conecting to the network. If some one for example like your naber see your network and conects to but put in the wrong WEP they will not be able to use your internet.
Jan 04, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Change password on Dell TrueMobile 2300 router
Hi, logon to your router using IE or whatever browser. Then follow these steps and let me know.
You are prompted for a Username and Password.
Type the username: admin
Type the password: admin
A note appears stating that Dell provides the advanced features for your convenience only. Dell technical support representatives can not support the configuration options in the Advanced Settings portion of the setup program.
Nov 29, 2008 | Dell TrueMobile 2300 Router (000001)
How do I set up a password to secure my wireless network??
Enabling the WEP for the Dell TrueMobile 2300 Wireless Router
Click the Start button.
Click All Programs.
Click Internet Explorer.
The Internet Explorer browser window appears.
Type the following in the Address line:
192.168.2.1
Click the Go button.
admin
admin
NOTE: If you previously changed your administrator password in the advanced settings of the router you will need type the password that you set.
Click the Basic Settings tab.
Click the Wireless Security button on the left side of the page.
The Wireless Security window will appear.
For the highest level of security choose the 128 Bit encryption option.
You will have to type a name for your encryption key in the field to the left of the 128 Bit option.
Click the Save and Restart button on the left hand side of the page.
The Save and Restart window appears.
Your settings will be saved to the router.
More Secure
Configure the 2300 Wireless Router for WPA-PSK with TKIP Encryption.
Double-click on Internet Explorer.
The Internet Explorer window appears.
In the Address Bar type my.router or the default IP address 192.168.2.1.
Press the <Enter> key or click Go.
The TrueMobile 2300 password window appears.
Type the User Name and Password.
NOTE: The default user name is admin and the default password is admin.
Click OK.
The TrueMobile 2300 Wireless Router configuration window appears.
Click Basic Settings.
Click Wireless Security in the left-hand pane.
Click to select Enable Wireless Security.
Under Network Authentication, select WPA (Wireless Protected Access) from the drop-down menu.
Input a network key or password in the field to the right of WPA Pre-Shared Key.
NOTE: Your network key or password can use 8 to 64 characters using Hexadecimal digits or 8 to 63 characters using ASCII characters.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 02, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Security
Hi.
Do the following steps
1. Open Internet Explorer, type on the Address Bar type http://192.168.62.1
2. You should see a box prompting you for your username and password. Enter your router username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
3. Click on Advanced Settings tab at the top, then go to Advanced Wireless tab at the side. There you can enable wireless security. Choose WPA-PSK or WPA-Personal and type your desired password then save or applythe settings. That's it.
Aug 02, 2008 | Dell TrueMobile 1184 Wireless Broadband...
Wireless security
Hi anthony - Could you please let me know the makes and model#s of the wireless pcs your running on your network. Also what operating system they're running. I just need to know because once you set up your routers' security you'll have to set up the wireless pcs with same security or they won't have access to the network. If you already know how to do that don't worry about it. Just thought I'd help you do that too. Just make a little list with one pc a line and each ones' info. Then I'll be happy to assist you. Thanks.
Jeff
Jul 20, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
727 people viewed this question
Ekse
Clive
Clive
