Question about Gaggia Classic Espresso Machine
Gaggia Classic out of storage
My beautiful gaggia came out of 7 months storage today. When filled and ready to go I switched it on and it leaked around the headste and all over the counter!!!!!
help me Obi-wan your my only hope!
  • harissa Jan 09, 2009
    I had the same problem following a move and 1 month storage. it worked perfectly prior to the move. water flows out through the casing and no steam goes through either the coffee part or the steam part.
    I took the top off and looked inside and can't see any corrosion around the boiler part (sorry i don't know the proper names for the parts!). is this seal actually inside the boiler part? it's not obvious to me how i would take that apart.
    gxmason - how did you ever resolve the problem?
    Sergeant:
  • Gaggia Expert
  • 223 Answers
Sounds like the machine was exposed to freezing temperatures?
If so, you probably cracked the boiler and the boiler section needs to be replaced.
Boiler for Gaggia Semi Automatic Espresso Machines
If you need to send it in for service click this link.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Posted on Jun 03, 2015
  • Gaggia Expert
  • 109 Answers
What is the model?
Exactly where did it leak?
Posted on May 08, 2008
  • ifr500 May 08, 2008
    Sorry didn't the model.
    If it's leaking from the group head the internal boiler seal will have perished.
    To confirm this remove the top cabinet screws,have a quick look, it will be all white with corrosion.
    It's a fairly involved job so if your not sure take it to a service agent.
    Good luck
SOURCE:
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Leaking water
If the machine is less than 6 months old then there could be some coffee aound the gasket use a toothbrush to clean the gasket and try again. If the same result, then the gasket needs to be replaced.
Aug 12, 2009 | Gaggia Baby Espresso Machine
Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone
to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Mar 03, 2009 | Nokia Bluetooth Headset Headset
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Carezza doesn't brew
May need priming -- follow the directions in the manual.
Jul 01, 2007 | Gaggia Carezza Espresso Machine
Gaggia Classic Espresso Machine Logo
282 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
