Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP OfficeJet 7410 All-In-One paper jam error
No jam sounds like the teeth aren't engaging on print cartridge carriage final pass. When the cartridges move all the way left there is a scraping zipper like sound & the error message appears again. Called HP & they said it might be a hardware/sensor issue. I'm out of warranty & don't have the bucks to pay for their troubleshooting. Help is more than greatly appreciated
Ed
  • Anonymous Jul 16, 2008
    Paper jammed in the the feeder. Can't get it all out.
  • Agnel Johnson
    Agnel Johnson May 11, 2010
    hi,
    if there is a noice from the printer, surely it is gona be a hardware issue. anyways let me know the error message that you are getting.
    thanks and regards
    agnel
    Genius:
  • 3,587 Answers
Well...let's just say your printer is speaking to you clearly...and too bad about warranty...you may want to consider a replacement printer, and recycle that one responsibly.
you may find a solution through this link(look for the google search, and select the fixyourownprinter.com option button).
Posted on Mar 16, 2008
Paper keep jamming
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 29, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer carriage jam and then locks
Dec 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
The problem is cartridge error.I cannot print.what will i do?
Nov 24, 2010 | HP Officejet 4355 All-In-One InkJet...
My printer says papaer jam but i don't see any paper in it
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 24, 2010 | HP Officejet 5610 All-In-One InkJet...
Replacement instructions for ink cartridge carriage assembly
Please follow the link below to HP Web site. This will take you to the HP 7410 Setup Chart. The cartridge instructions you need begin in frame 10.
http://h10032.www1.hp.com/ctg/Manual/c00236206.pdf
Don
Oct 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
It is telling me cartridge error What does that mean
Did you just replace a cartridge. Sounds like you used the wrong one.
Oct 01, 2009 | HP Officejet 4215v All-in-One Printer
OFFICE JET 7410 PRINTER
Check the cartiridge if it is sitting nicely on its place. it seems you dint place the cartirdge properly
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Cartridge jam
Sorry, bad carriage assembly, uneconomical to repair.
Jan 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Not printing
If either a paper jam or blocked carriage error message appears
in the front panel display there might be some packing material
inside the HP Officejet. Lift open the print-carriage access door to
expose the print cartridges and remove any packing material or
other items that do not belong there.
Jul 28, 2008 | HP Officejet 4215v All-in-One Printer
7410 officejet
Sounds like the printer isn't passing the self diagnostics. Check for paper jams, pull the paper out and put it back in, check the ink cartridges.. unplug the equipment for about 30 minutes.
Mar 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
254 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
