Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A
Kenmore Upright Freezer Model 2539252110
My freezer appears to be working but it makes a constant clicking noise ( relay energizing?) after I manually defrost it. When it has a build up of frost it doesn't seem to do it. I don't want all the frost on there because it is less efficient that way right? ...but then after I defrost it it seems to want to cycle something on..or off constantly. Like I said it gets cold and keeps things frozen but something doesn't seem right.
  • Frigidaire Master
  • 2,651 Answers
Constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
Posted on Mar 18, 2008
My upright freezer works great but it makes a clicking noise like every thirty seconds or so.
These are the parts that would make a clicking noise. it is up to you to pin point where it is coming from:
ok try to pin point if the clicking is coming from the inside or the outside
you can go to hit the parts link then enter the model number. you can view a diagram and it will show you where the parts are at
hope this helps
Mar 17, 2010 | Kenmore Freezer 14.1 cu. ft. Upright...
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Picked up used chest freezer...plugged in and briefly clicks...I can hear it energized for about 5 seconds then then repeats this cycle. It was on its side when delivered
Try to replace the compressor relay (most of the times problem) ,but if still doing the same clicking noise , the problem is in the compressor.
Sep 29, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
May 24, 2009 | Haier 9.1 cu. ft. / 258 liter Upright...
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A Logo
145 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
