Question about Cook's Essentials Smoothie Maker Work Top Blender
Cooks Essential Smoothie Maker
I need to order a new plastic top piece for my smoothier maker ; when taking my pour spout on and off the plastic piece has a crack in it and has broken off . Can I just order a new top piece for my smoothie maker???
  • Anonymous Mar 30, 2008
    the spigot on our smoothie maker has also cracked and we need a new seal.
    Problem Solver:
  • 5 Answers
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
Cooks 5 in 1 power blender replacement cups
replacement cups can be found at amazon, click here and take a look: Amazon com cooks replacement parts cups. I hope this was helpful. Cheers
Nov 04, 2012 | Cook's Essentials Smoothie Maker Work Top...
Can I get replacement parts for a Disney Smoothie maker SD4RED.
Sure, you can contact the manufacture or, go online as well to the manufactures website for parts info and purchase details.
May 29, 2009 | Back to Basics SD4RED Disney Smoothie...
Villaware smoothie maker
just call food saver at 1 877 777 8042 same company as villaware
Feb 06, 2008 | VillaWare 5785 Smoothee Bar Work Top...
Cook's Essentials Smoothie Maker Work Top Blender Logo
386 people viewed this question
Top Cook's Essentials Blenders Experts
Ross Keen
ray gallant
Tom Chichester
Are you a Cook's Essentials Blender Expert? Answer questions, earn points and help others
