Monitor connection problem....
I'm using an acer flat panel monitor and an older computer...about eight years older. The computer worked just fine before...but the monitor won't
recognize the tower, it just says there is no signal...
Any ideas....
  • 24 Answers
Check your battery in your computer, it should read 3Volts, if it don't you need to replace it. If it is fine, then your monitor don't work.
Posted on Mar 16, 2008
It stopped working
check the power supply board which failed. look for blown fuse and replace any bulged capacitor.
Sep 07, 2012 | Apple LED Cinema Display 27 inch flat...
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Built in speakers do not work
Have you connected them to the pc's sound card - it doesnt go through the video cable.
Apr 24, 2009 | Acer AL1717-BBMD 17" LCD Flat Panel...
Dell computer will not work with an older HP monitor
no dell have set up there computers so you cant use othe appliances that arnt dell. so im sorry for the inconveince.
please rate my help to you.
thank you.
Apr 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Resolution issues with Acer LCD al 2216w
Possibly this will help. I have installed two1680x1050 LCD screens this past year: your 2216W model on a new PC, and a similar model from another maker on my wife's older HP PC.
Mine worked at the native resolution, my wife's did not. Difference: the age of the computer's (actually Windows XP's) native software for monitors. I went to Control Panel, Display, Advanced, and slid the left-hand slider control to view the various resolutions available. On the newer computer, the highest resolution choice was 1680x1050. On the older computer, the choice was not given. The choices stopped somewhere areound 1270 by 1080.
Solution was to download the newer driver from (as I recall) the computer manufacturer's website, using their regular download/update channel. That gave my wife's older computer the necessary top-end resolution. It was not something the monitor manufacturer could have fixed.
Dec 12, 2008 | Acer AL2216W LCD Monitor
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
