Question about Compaq Evo N610C Notebook
Hidden screws on compaq n610c
Excuse me, but i'm going crazy with my compaq n610c.
How the hell can i open it? I took off every screw i can see, but it won't open...tere must be other screws hidden somewhere but i can't find them! Please, HELP!
    Scholar:
  • 105 Answers
Full maintainance and installation guides in adobe acrobat format are available here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=321957&prodSeriesId=316664&lang=en&cc=us
they contain complete disassembly instructions.
Posted on Mar 16, 2008
    Sergeant:
    Champion:
  • 256 Answers
Hi
Try display resolution to reduce it will solve problem.
Thanks
SOURCE:
Where is memory located in compaq n610c laptop
It is located in the lower panel underneath a panel the has a icon of two rectangular boxes put together you need to open the screw and you would find the RAM or the memory located there.
Feb 18, 2010 | HP Compaq nc6000 Notebook
Where is the memory module located on the Compaq Evo model N610c?
turn over computer. remove battery(this is vital) then underneath will be a small panel, with a phillips head screw in middle of computer..remove that screw. make sure you 'ground' your hands, before touching the memory modules, AND only touch ends, not the gold fingers..
Nov 28, 2009 | HP Compaq Evo Notebook N600c
How to install ram in a compaq evo n610c notebook
Daniel,
Laptop must be powered OFF...
On the bottom of the laptop, open the hatch for the memory compartment. It is the 4" square hatch with a single screw.
Note the way the current memory is placed. The two memory sockets may be full. Remove one module using both hands to separate the "catches" on the sides of the module.
The module will "pop up". Replace the memory using the reverse by seating the module into the socket, then press down until the module "snaps" in place.
Close hatch.
Oct 13, 2009 | Compaq Evo N610C Notebook
I cannot open my compaq evo d51s, any ideas?
if you look at the back of the workstation you will find a hidden screw next to the air vents, locate and unscrew, the casing should slide back away from the front and lift off to access the optial drive and ram
Apr 27, 2009 | Compaq Evo D500 PC Desktop
Compaq Evo N610C Faint Screen
Usually it's the inverter. Sometimes it's the backlight / lcd, and occasionally it's the lcd cable and or video card.
Easiest thing to do is order a replacement inverter from ebay. They're cheap and then swap it. You just need to remove the outside lcd bezel, it's just four or five screws and you're in business.
Feb 22, 2009 | Compaq Evo N610C Notebook
Access to ram
The n610c has RAM accessible from underneath the laptop. There will be a cover with a logo looking like a computer chip near it. Should be 1 screw to access it.
Feb 05, 2009 | Compaq Evo N610C Notebook
Casing
The memory socket is located below and to the right of the keyboard. The panel is to the right of the mouse pad.
The keyboard needs to be removed. DO NOT REMOVE THE KEYBOARD CABLE! Remove the screw located in the middle lof the underside of the n610c. Slide the four tabs located on the top edge of the keyboard toward the space bar. The tabs are located to the right of the esc, the F4, the F8, and F12 key. Using a flat blade screwdriver gently lift the top edge of the keyboard, once it is lifted slide it toward the screen.
The panel covering the memory may require "gentle force" to remove.
Jan 04, 2009 | Compaq Evo N610C Notebook
Clear power on password
Removing the Time of Year battery will clear the BIOS password. It is located on the underside of the n610c behind the panel covered by the Microsoft COA label. A small phillips screwdriver is required to remove the two screws on the panel. Carefully lift the BR1225 battery with a small flat blade screw driver.
After 10 minutes re-insert the battery. The BIOS Password should now be cleared, as well as other BIOS settings, the time and date.
Sep 09, 2008 | Compaq Evo N610C Notebook
Compaq evo n610C adding ram
Hi, the ram is located under a cover to the left of the mouse pad, you need a flat blade screw driver to pop it open.
Jun 26, 2008 | Compaq Evo N610C Notebook
Ram upgrade
youll find your memory underneath your laptop beneath a compartment door which is secured by usually one screw.remove screw and lift hatch to view mem.either one or two slots will be available.mem looks like oblong board with chips on it.at either side of memory board are clips.push clips outwards and lift out mem board.when clips are removed mem board will lift to about 45 degree angle.to put new mem in; place board in housing ,dont worry they only go in one way ,then push down till clips secure
Mar 01, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
862 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
