I have forgotten how to thread this machine as it has not been used in a long time. Where can I get instructions?
It's a waltons celestial model 866
Thanks Katseyes
Perhaps this video will help. Not your model, but there are similarities that will help. NOTE: Before threading the upper thread, RAISE the presser foot so the thread will seat properly in the tension disk.
Kenmore 158 17550 Sewing Machine Tutorial
How to use your basic sewing machine 1
Before trying to sew, test your machine by turning the handwheel manually. If it is hard to turn, parts do not move or when you try to run the machine, it bogs down and does not operate, then you need to do some maintenance since the oil has probably dried out while in storage:
Treat your machine to a good cleaning and some Fresh "good quality" sewing machine oil (not 3-in-1, WD-40, cooking oil, or stinky brown stuff from the bottom of the sewing basket). Do not oil rubber, leather, plastic, or belts as the oil may damage them. Look for little holes that are oil ports. Apply 1-2 drops in each. Then gently rotate the handwheel and apply a couple drops every where that metal rubs on metal. Don't forget the bobbin area!
The following videos may help or you can search YouTube for other videos.
https://www.youtube.com/watch?v=xh4SeRdqBiw
I think it will help if u explain by pictures please for how to thread brother sewing machine vx 1450
Hello :
Here I'll tell you how to thread a sewing machine . Just let me know if that worked or not to provide another help .
Things You'll Need:
I hope that will help .
Don't forget to rate if that was useful please !
