Question about Car Audio & Video
Kenwood KDC -X969 Won't power up
Stereo will not open, or power up.
I have replaced fuses, but not fixed.
However, when the fuse is pulled, or batery is disconnected and re connected, it seems the stereo resets, opens half way for 3 seconds, then closes and goes dormant again. With the back plate off, I do see a flashing red light.
I have cleaned connections as well....????
Any ideas?
  • 4 more comments
  • caminator Apr 21, 2008
    hello, I´m Tomas from Spain.
    i ´ve the same problem, i turned the ignition off ,and the black panel (theft deterrent panel) was moved a little bit. and no power up again.
    battery reconected, open 3 seconds, no lights and close.
    could you solved it ?
    i appreciate your replay.
    many thanks & regards.
    TOMAS RUIZ
  • scottlopez Nov 28, 2008
    Same problem, opens for 3 sec and closes. I do have the red security light with the face plate off also. It worked fine the day prior. Have any answers, please?
  • Anonymous Nov 30, 2008
    I have the exact same issue. I have temp replaced mine with a cheap-o pioneer that already crapped out itself by having loud feedback noise (was not there with the x969 installed, but decided to show up a week after the install of the newer headunit). I checked all my grounds, fuses, power, etc.... I miss my x969.
  • Newton McDuf Dec 29, 2008
    Same thing! Can anybody figure this out?Thanks.
  • Anonymous Dec 30, 2008
    Same problem with mine. Bought in Dec '03 from Ultimate Electronics. I called Kenwood and they said to take it to a service center, but the review cost is $100!
  • Anonymous Jan 13, 2009
    IHAVE THE SAME PROBLEMS AS THE WITERS ABOVE THAT THE KENWOOD KDC-X969 HAS LOCKED ME OUT OR [email protected]
    New Friend:
Try pressing the reset button when it slides halfway open. It's a little hidden on the main button panel at the bottom. You'll need a pencil or something to press it. This usually happens to me when it's too cold and I have the panel angle set to full down tilt on my 879.
Posted on Nov 30, 2009
SOURCE:
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
I have a Kenwood KDC-MP2032 installed in a boat. I changed the battery in the boat and now I can't get the tuner to power on. If I need to replace a fuse, where are they and what size fuse do I...
Try to check first the fuse on the fuse box of your boat if it is still good then the fuse of your stereo is located at the back of the stereo itself. Detached the stereo from its housing or holder you will see the fuse at the back of it.
Jun 28, 2011 | Kenwood KDC-MP2032 CD Player
Kdc-x969, when the unit is tured on the face does not flip down. most buttons turn the unit off but the face flips down instead of up when it shuts off
It very well could be that the internal motor that moves the faceplate is going out or has already gone out. It sounds to me like that could be the problem.
Apr 12, 2011 | Kenwood eXcelon KDC-X969 CD Player
How to change the fuse on a kdc-mp2035
Hi.
You need to pull the unit out from the dash. At the back side of the stereo you will find a 10-amp fuse inserted into the chassis of your Kenwood.
See the red 10 amps fuse on picture below:
Mar 15, 2010 | Kenwood KDC-MP235 CD Player
Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Feb 26, 2009 | Car Audio & Video
Kenwood x969 not working
hi,this unit sounds like one with a motorised face. the problem could be with the flat ribbon cable connection between face and main pc board. chech for cracks alond the body of the ribbon especially where it bends alot. Also try resetting the unit if the unit has a reset switch or reset function.
Aug 03, 2007 | Kenwood eXcelon KDC-X969 CD Player
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Car Audio & Video Logo
419 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
