Question about Emerson Smartset Clock Radio
This AM it started blinking and will not stop It is less than 1 yr.old.
It changed correctly for day light savings time .Until now I havent had any problems.The screen is dark but I can see it blinkink.I also can not find the booklet that cam with it.Please Help1
The projection light comes on
    President:
  • 814 Answers
Sorry it took so long to reply to your question. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day
Posted on Jun 15, 2009
SOURCE:
My 10 yr old Sony KP-51WS520 rear projection tv come on for about 10 seconds and then shuts off.
Sadly yes. that is repairable but a 55" flatscreen TV is pretty reasonably priced these days. It will use a lot less electricity as well.
Jun 09, 2015 | Sony Televison & Video
How to set clock in radio on a 2014 Jeep Patriot
Clock Setting Procedure 1. Press and hold the TIME button until the hours blink. 2. Adjust the hours by turning the right side TUNE/ SCROLL control knob. 3. After adjusting the hours, press the right side TUNE/ SCROLL control knob to set the minutes. The minutes will begin to blink. 4. Adjust the minutes using the right side TUNE/ SCROLL control knob. Press the TUNE/SCROLL control knob to save the time change. 5. To exit, press any button/knob or wait five seconds http://www.chryslercommercialvehicles.com/jeep/download/pdf/manuals/2014-Patriot-OM-1st.pdf page 240
Mar 12, 2015 | 2014 Jeep Patriot
How to change the date
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational.
Dec 20, 2010 | The Times ROYAL TC100 TimeMaster Time...
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Can't set time, etc. on Ottimo Billboard Solar watch.
I just picked up this watch.  Setting it is easy.  Hold down the button marked "RESET" (lower right) until the numbers start blinking.  Hit the "MODE" button (lower left) until the the settings you want to change are blinking.  Hit the "ST/STP" button (upper right) to change that setting.  Keep on hitting these two buttons until the settings are as you would like them.  Hit "RESET" button to finish.  So, to change just the day, I would hold down "RESET," hit "MODE" four times, hit "ST/STP" until the date is correct, hit "RESET" to save.
Dec 20, 2008 | Bulova Watch
I get CL blinking on the base
A flashing “CL” in the message window indicates that you must set the correct
day and time at the base unit.
1. Press the TIME button. The system announces the time and day of the week,
followed by "To set day and time, press TIME/SET."
2. Press the TIME button. The system announces the day.
3. Press the CHANGE button repeatedly until the system announces the correct day.
4. Press the TIME button to save the new setting. The system announces the setting.
5. Press the CHANGE button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6. Press the TIME button to save the new setting. The system announces the minute.
7. Press CHANGE to advance the minutes one at a time. –OR– Press and hold the
CHANGE button to advance the minutes in increments of 10.
8. Press the TIME button to save the new setting. The system announces the year.
9. Press CHANGE to advance the year one at a time. –OR– Press and hold CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME. The system announces the clock setting.
Mar 24, 2008 | Motorola Mobility E51 MD7161-3 Quad...
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
Timex 1440 sports watch, WR50M
In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
Feb 15, 2008 | Timex 1440 Nylon watch
Emerson Smartset Clock Radio Logo
254 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
