Question about Sanyo DS24205 24" TV
White line across the screen on the sanyo ds24205 24" tv
I have a white line across my tv everytime i turn it on
the sound is a buzzing noise and the channels move but it goes right back to the white line
i would like to know how to fix this
    Problem Solver:
  • 20 Answers
Vertical ic probably bad.
Posted on Mar 17, 2008
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a 1995 Sony projction tv that has started flickering white lines across the screen while making a sort of buzzing noise like a lightbulb that is not all the way plugged in. Recently the problem has...
Most likely the problem is in the high voltage section if you are hearing a buzzing noise. There is not much you can do. This is a dangerous circuit to work with. Have a repair shop check it for you. Thanks
Oct 28, 2009 | Televison & Video
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Snes -horizontal white lines and buzzing noise
the best bet is to obviosly try another rf cable or try anothe snes unit.
Jul 06, 2009 | Nintendo Super NES Console
Black screen with a horizontal white line across the middle.
You would need to replace the flyback on this and your looking aroung $65 parts and $85 labor to shore this problem up. We can recommend you a repair shop or you can purchase a new TV its all up to you
Rulds2008
May 02, 2009 | Sanyo DS24205 24" TV
High pitch buzzing.
Hi there
Let's make ur problem a bit clear. "white lines" how? where?
meaning retrace lines with full raster or a single vertical line?
buzzing sound? without even turning the power switch of the TV to "ON" or when u just plug the power cord?
I'll check for schema, mean while can u tell me where the resistor leads to? is it a fusible resistor? if so , to which area the resistor suppliers power?
Regards
Rifaa
Nov 12, 2008 | Zenith C27A24T 27" TV
Sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
May 26, 2008 | Sanyo DS25390 TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Sanyo DS24205 24" TV Logo
324 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
