Question about Dell 1600n All-In-One Laser Printer
Dell 1600N printer paper jam
Hi, our printer isnt able to properly pick up the paper and print it. paper gets jamed on first paper. what do we need to replace and where do i order that from? thanks
  • mrnodalo Dec 22, 2008
    i have the same problem w/ my dell 160n printer it keeps giving me paper jam0 error which the paper is not getting pick. So does anybody knows the part name? is it pickup roller or transfer roller?
More than likely you need a new pick up roller. It is located at the top of the tray area in the printer. You will see a black rubber roller with white nylon clips on both sides. You can confirm if it is the problem by removing and washing it with soap and water, then clipping it back in and running a few copies.
Posted on Jan 14, 2009
I have found that Hair Spray has worked the longest for me. Remove the roller hit it with the hair spray. let it dry and reinstall.
Posted on Apr 29, 2009
We also have had this problem. On the paper tray when it is slid out there is a rectangular button. This should have a metal clip on top of it. If the clip is missing rubber is exposed. So when the roller with the rubber grip grabs the paper the rubber on the button stops the paper from moving. Try putting a piece of tap on the rubber button for a temporary fix, and then order a new paper tray.
Posted on Aug 01, 2008
    Scholar:
  • 105 Answers
There is a rolling mechanism (long bar) in the front that has a rubber grip on it. This sometimes wears out. You can purchase kits for some printers, but an easier route (to try first) is to moisten the rubber grip (it is shaped like a U) with Windex or similar liquid. You need to remove the paper tray, turn printer upside down and try to print something. You can trick the printer into thinking the tray is in place by pushing in the black tab that extends from the metal housing (take out tray and turn over, you will see it is a spring-loaded curved piece). While the roller spins, get it wet.
Another common problem is that the tray itself is sticking. It should, when slid into the printer, pop a small white arm that releases a spring-loaded "ramp" that lifts the paper so it is close enough to be grabbed by the roller.
Posted on Mar 27, 2008
DELL 1600N ADF JAM. IT ISNT PICKING UP THE PAPER. THE GEARS ARE TURNING BUT IT ISNT GRABBING
Hi I had the original problem too, but the cheapest replacement part I could find is 30 pounds.
So I stuck a piece of sellotape over the white bit and trimmed the edges so it didn't catch the paper on the way over. Works for the moment.
Oct 21, 2011 | Dell 1600n All-In-One Laser Printer
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Dell Printer 1600n
Check your manual feed tray. The printer may have a print job in memory that's pointing there.
Aug 13, 2008 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Rear output slot
What do you mean? Do you actually want the paper to deliver out the back? Do you need the part that goes to the back so the paper delivers properly? Explain...
Call Dell Services. They will be able to help you purchase any part you need.
Mar 11, 2008 | Dell 1600n All-In-One Laser Printer
Dell Laser MPF 1600n WON'T PRINT
Two causes:
1. Worn out roller
<or>
2. Spring-loaded tray not engaging when placed into printer
1. The roller will try to "grab" the paper when the job starts. If it becomes too worn, it will slip and not grab anything. One fix is to apply a small amount of moisture to the u-shaped rubber roller.
Other option is to wrap a rubber band around it if you can.
2. Check to see if tray spring works properly. There is a small white knob on left side of tray. Push paper in tray down all the way until it clicks. Engage knob on side and paper should spring upwards. If this does not happen, the roller will not be able to engage the paper and it will simply click as it tries in vain.
Dec 07, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
3,298 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
