Question about Sony PlayStation 2 (PS2) Console
Playstation 2 not working not turning on
I opened the playstation, disconnected all wires, ribbons etc... as i was having a disk read error but now when i connect everything back and try to turn it on, its not working at all?
could i have hurt the silver ribbon? if so how could this be fixed.
its a charcol black playstation 2 model SCPH - 50003.
many thanks
vicky
  • Anonymous Mar 18, 2008
    no support from emulator if cd is runned
    Master:
    Sergeant:
  • 482 Answers
I would replace it with one on ebay, they are cheeper then ever
Posted on Mar 17, 2008
SOURCE:
Disk read error, turn console on goes to system configuration press x goes to mem card and says reading disk then says disk read error
This is a result of one of two things-
1) Your disc is dirty, damaged, or scratched. To fix this just clean it gently with a wet cloth, if it still doesnt work you can take it to a game store to have it cleaned there. It is possible that it is scratched to much and is unable to read at all.
2) Your Playstation 2's reading laser has become damaged or dirty. I suggest blowing air through the system with your mouth or preferably a can of compressed air which can be purchase at most retail stores.
This error seems most likely to be a disc issue.
May 16, 2011 | Sony PlayStation 2 (PS2) Console
My ps2 does not read any disk
Try with any audio disk, if it does not read, then it might have lens error. There can be more then lens problem, including motor, lens ribbon etc. If you do have a cd lens cleaner, try to clean the lens and check again. If problem dosn't goes, contact your nearest dealer, the device is very complicated for you to service. Thanks
May 16, 2010 | Sony PlayStation 2 Slimline Console
Error 80029725 ps3
If you've had this unit apart recently open it back up and make sure ALL ribbon cables and wiring harnesses are slotted correctly. I had an error code problem and it turned to be an incorrectly seated ribbon cable.
If that doesn't fix the problem try formatting the drive, it could be a corrupt file on the hard disk. Make sure you back up anything you want to save on a flash drive first.
Apr 17, 2010 | Sony PlayStation 3 40GB System
Playstation 2 disk read error starting with no warning
your ps2 lens may be damage.lens need cleaning or lens preset will be wrong posion.if you know how to open ps2 cover then you can try turn preset to right position otherwise you have to repair.sorry for bad english.
Dec 18, 2008 | Video Game Consoles & Games
Playstation 2 is not reading disks
my playstation can not play nstc disks
Oct 25, 2008 | Sony PlayStation 2 (PS2) Console
Grand Theft Auto 3
Then yeah its just that there is an error reading the disk. Try to clean it or get a new GTA3 game.
Jun 30, 2008 | Sony PlayStation 2 (PS2) Console
Disk read error
First of all dont play PIRATED games.
But for the solution , if your console is modded for playing pirated games, then any of the soldered wire through the modded chip may be disconnected or may be loosen. The soldering sometimes gets off the connections(the soldering guy may be ignorant) . So check your ps2.
Mar 26, 2008 | Sony PlayStation 2 Slimline Console
PS2 won't work, red light comes on, buttons don't respond
Sounds like the ribbon cable is ether damaged or not in the slot all the way.. that clicking sound you hear is common after extended use, all mine make the same sound ..try opening it up one more time and check the ribbon ends i know it's a pain but might be worth your time. pulling them out too hard can damage the ends.some time's putting them they seem like there in all the way but it might not be in straight.REMEMBER BENT FOLDED FLAT CABLES = problems.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Disk Read error
Re order the optical carrier ribbon, form the net and also make sure the optical laser is the right class, amp. Volt and resistance as the normal one. If you put in a different 'class' laser the device could be more damaged... hopefully not. Now your warranty is out the window as you have opened the box yourself. Firstly the easier thing is to buy a whole new blue ray device, it should be a Sony, (no surprise) just quote the serial number and device name on the web or on the phone and volla! Install the device and everything should be working. Good luck.
Sep 24, 2007 | Sony PlayStation 2 Slimline Console
Wont read disk
PS3 is The amazing device by sony but it has some common problems like Disc read error, video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
135 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
