Question about Frigidaire Affinity ATF7000E Front Load Washer
Error 59 - Washer not spinning
Error 59
Model ATF7000EG; Washer is 18 months.
Inside drum is not turning, so it seems that the motor is not spinning.
  • Anonymous Jan 06, 2009
    washers doesnot spin
  • 240 Answers
Find tech sheet at bottom of washer, behind kick panel on left and check error code there and if listed follow check for motor controller. if not draining either then check drain pump.
Posted on May 04, 2008
SOURCE:
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Stopped in mid-cycle. drum will not turn even by hand, unloaded. Plastic/metal debris in filter.
If you have a front load washer, sounds like you do, by your description. If you can't turn the drum by hand and have foreign object within the pump filter, its time to replace the washer. It sounds like your spindle has cracked and the tub will no longer be suspended from the rear. Metal from the spindle and plastic from the basket (spin drum). Sorry for the bad news but its cheaper to replace the washer than fix the damage. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 18, 2016 | Washing Machines
59 Error code washer Frigidaire Gallery
Hello - Typically error code 59 indicates that that washer is not detecting a tacho signal for three seconds. Contact a professional to move forward accurately. Technician will need to remove the belt from the motor, spin the motor pulley and diagnose the speed control board.
Nov 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
Error reading LE. How can I fix this without calling repair guy. Washer spins but once the water is inthe machine it will not spin.
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Jan 26, 2011 | LG WM1814CW Front Load Washer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Jul 20, 2007 | Kenmore 43142 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
344 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
