Convert Amstrad Word Processor Files to PC
Hi, my mum has a load of old Amstrad disks with various files on, in formats Locoscript, Protext & Mini Office Professional. She does not have the actual Amstard anymore.
How can we go about getting these onto a pc?
How can we convert them so they can be read, edited?
Is there any hardware we can buy (ie. floppy drive), so that we don't have to send them to a company to convert?
Regards, Rohan.
    Sergeant:
  • 349 Answers
I would suggest you search the internet for freeware ,of the same type of program you have on the old Amstrad disc's
they will be:
  • Free
  • better quality
  • up to date
it just would not be worth while trying to find then use an emulator, if in fact there is one available to do what you require,
good luck
Terry
Posted on Mar 17, 2008
6ya staff
SOURCE:
How do i convert FAT 32 to NTFS without formatting / Loosing Files in my Hard Disk Drive?
1) Backup your data!
2) XP or later: Open CMD (DOS Window) "Convert" [Drive:] /fs:ntfs
To verify you have the command available, in Cmd window, type "convert /?" that should bring up the various parameters to use with the command. If convert is not available, it will return "unrecognized command".
Apr 03, 2015 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Psion Revo replacement restore
What do you do if you no longer have access to a Psion, but need to access some data from an old Psion backup on your PC? Native Psion files can't be read on a PC, but fortunately, there are some solutions:
  • Use the PsiWin PC connectivity suite to convert the Psion-format files to a format that can be read on the PC.
  • Download and install the Psion ER5 emulator - this gives you a Psion machine on your PC, and will allow you to access your old data on a PC - See our emulator setup page. From the emulator, you may be able to print or export your data to a text file, or use a third -party Psion converter
  • Consider borrowing or buying an old Psion machine, loading the files onto the Psion, then printing the documents or data as a text file
  • Find another friendly Psion user that may be able to convert the file into a format that can be read by a PC for you. If you don't know of another user, try asking for help in our Psion forum
also
Data conversion for the Psion can be quite complicated, due to the file formats used by Psion / Symbian. You should find that the PsiWin program supplied on CD with your Psion machine can help you with most of your conversion needs. If your PC is connected to your Psion, dragging files from "My Psion" to the PC should prompt you to convert to a PC format, otherwise you can convert files that are stored on the PC, using the Psion File Converter. This program is installed with PsiWin and is located in c:\program files\Psion\PsiWin - the application filename is Cpycnv.exe
psiwinconv.jpg For more help on file conversion, see our dedicated conversion page.
Agenda and Contacts databases: Note that these can't be converted using the Psion File Converter - PsiWin supports synchronisation of these files, but not direct conversion. See our suggestions in our Backup FAQ. The most common solution is to load up the files in the Psion Emulator, and either use Print to save the data as a plain text file, or use a Psion-based converter, as detailed on our Conversion page
Sep 17, 2008 | Psion Computers & Internet
Tip
Join various MTS files-Import and Convert different AVCHD MTS files to ProRes...
Join/Convert Panasonic/Canon/Sony/JVC various MTS to ProRes for FCP without rendering <br />Edit all MTS Videos on FCP-Merge/Convert HD Camcorder MTS files to FCP ProRes on Mac <br /><br />As the reason of recent activities, I have a lot of <b>different .mts Videos for Editing</b>. These .mts video most are from camera, camcorder, like Sony CX700, XR520,Sony Nex-5, Canon HF G10, HG20,HF100,Panasonic HDC-TM90,SD700,Lumix GH2.etc.Some .mts videos can be directly into FCP editing, some not. So in order to <b>Edit all MTS Videos on FCP</b>, I need a converter to <b>Import and Convert various MTS</b>. But separating each video conversion is a lot of trouble, so I will need to <b>merge those mts videos into one and convert</b>. Through Google search, I found Aunsoft Final Mate for Mac is the recommended <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS Joiner/Converter</a></b>- can <b>join and convert mts to FCP for editing on Mac</b>. Then I download and try it. And I had successfully <b>converted a total of 15.8G mts files to MOV and edit on FCP</b>, I choose the Apple ProRes MOV as output format, so that I can <b>import prores mov to fcp without rendering</b>. <br /><br />Following is the experience of using Final Mate for Mac to <b><a href="http://prores-converter.com/2011/06/joinconvert-panasoniccanonsonyjvc-various-mts-to-prores-for-fcp-without-rendering/">Merge and Convert Panasonic/Canon/Sony/JVC various AVCHD MTS files to ProRes 422 for editing on FCP</a></b>. <br /><br />Step 1 : Import various mts Files from Computer to <b>Final Mate for Mac</b>. <br />Click "Add" to browse computer and select a folder where video files are saved, then click "OK" to display all video files including various MTS files in Resource Tab. <br /><br />Step 2. Create a Movie for <b>Combining/Converting AVCHD MTS files</b>. <br />Soon after the mts files are imported, you need to create a movie for conversion. There are two ways for you to create a Movie for <b>converting imported various MTS files</b>. <br /><br />- The easiest one is dragging and dropping displayed various MTS files from Resource Tab to a single Movie. <br /><br />- Another way is clicking the drop-down button of "Add Movie" icon and choose "For Conversion" to create a blank movie. And then drag and drop the video clips from Resource Tab to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /> <br />Step 3. <b>Export ProRes video file for Final Cut Studio</b>. <br />Click the Export and choose Final Cut Pro &gt; Apple ProRes 422 HQ (*.mov) to output format for editing in Final Cut Pro. <b>Apple ProRes 422 , Apple ProRes 4444</b>,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br /><b>Tips:</b> You are free to set/adjust output ProRes MOV files parameters (Bit rate - high quality, Frame rate - 30, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. <br /> <br />Step 4. Click OK to start <b>Joining and Converting different AVCHD MTS to ProRes</b>. <br />Click OK button, the software will automatic <b><a href="http://www.aunsoft.com/final-mate-mac/">Join and Convert the various mts files into one big files</a></b>. <br /><br />When the conversion is finished, you can get big files for <b>importing and editing on Final Cut Pro without rendering</b>. <br /><br /><b>Tips:</b> If you are using Final Cut Pro 5 or lower version, ProRes is not the best format for you. However, you can choose QuickTime Movie Format &gt; Apple InterMediate Codec(AIC) as output format for editing on Mac.
on Jun 21, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert MKV Video to MP4, AVI, MOV with MKV Converter for Converting MKV on Mac
How to convert MKV file (.mkv file) with MKV Converter for Mac? Here is the best MKV converter, MKV file converter to easily convert MKV files to MP4, MOV, AVI and other common video formats with fast speed and high quality. It’s really a helpful Mac MKV Converter to convert MKV Videos to iPod, PSP, Apple TV, PS3, Xbox, etc or extract MP3, WAV, WMA, AAC or M4A music file from MKV file to enjoy on various digital players.
MAC / Apple instructions to convert MKV movie to Apple TV/iTunes/iPod and more.
Step 1. Free download MKV Converter for Mac
l. Install and run it
Step 2. Add MKV files. This Mac MKV Converter can convert MKV to almost all video format such as MKV to MP4, AVI, MOV, 3GP, DV, 3G2, SWF, MPEG, WMV, FLV, etc.
Note: You can load two or more MKV files or foler using this MKV file converter.
Step 3. Set Output.
Click Profile drop-down to choose files you want to convert video format.
You can reset video parameters and audio parameters etc.
Choose MP4/MPEG-4 movie format for enjoy MKV video on Apple TV/iTunes/iPod, etc.
Choose MOV format for importing MKV on Mac QuickTime, iMovie, FCP, etc
Choose AVI format for Windows Movie Maker, Windows Media Player, etc.
Step 4. Save output folder.
Tips: Before the video conversion, you can edit MKV videos, clip video into small pieces, merge different files into one, add special video effects, etc.
Step 5. Click Start button to convert MKV files to MP4, MOV, AVI, etc video format.
Ok, done.
As the website says it is a professional MKV converter tool designed to transform MKV file (Matroska Video) to various formats HD Quick Time Video, HD MPEG4 Video, HD AVI Video and transfer MKV to SD MP4, AVI, MOV, 3GP, DV, 3G2, SWF, MPEG, WMV, FLV, etc. Doremisoft MKV Converter is just a good Mac Pro like this.
How to import MKV hd into iMovie?
on Jun 17, 2010 | Computers & Internet
Ihave downloaded AVI movie files onto my iomega screenplay MX but they wont play,can you help?
Hi, Convert that's movie files compatible in your iomega screenplay MX files like mp4 etc. To download free any video converter software for PC click the following link http://www.filehippo.com/download_any_video_converter/ then install > double click> next>finish. icon already in the desktop. Also download this http://www.filehippo.com/download_vlc/ VLC media player for PC's is a highly portable multimedia player for various audio and video formats as well as DVDs, VCDs, and various streaming protocols without external codec or program.
Jun 28, 2011 | Computers & Internet
My phone doesnot read wma format songs
ensure that you have the correct .wma extension when you put them on your phone. Few phones do read .wma. Try turning your .wma files on your computer to .mp3 files with a converter.
Jul 01, 2009 | Nokia N70 Cellular Phone
Need to convert old brother disks to windows
If you can save the files as a text only you may be able to read then with MS word or any word processor.
Apr 04, 2009 | Computers & Internet
AMV movie dowloads - JNC Movie Mojo ( SSFM-220 )
How to convert wmv, asf, avi, mpg to amv files? iOrgsoft AMV Converter is an easy to use video-to-AMV and AMV-to-video converter application that enables you to extend MP4/MP3/MTV capacity by converting various video files into AMV workable format. AMV Converter has powerful editing capacity that you can customize source video files into different resolution, bitrate, frame rate, etc.
If you have lots of video sources but unable to get them onto your player, AMV converter should be your ideal choice. Please follow the guide below on how to convert AMV video file to or from using the iOrgsoft AMV Converter.
spacer.gif icobuy.gif Buy Now spacer.gif icon-downarrow.gif Download RMVB Video Converter free trial spacer.gif How to use video to amv Converter
How do you convert video files into AMV video files that are compatible with your mp3 mp4 player?
Step 1. Download and install iOrgsoft AMV Converter
iOrgsoft AMV converter is a simple-to-use program with intuitive way of operation. You are supposed to download a trial version to evaluate the program by converting video into AMV, we welcome you contact our customer service with your problem.
Step 2. Load video info
Click ADD Files to load video info. You can load as many video files in different formats as you like, the batch mode and powerful code pack within the program can easily take care of every thing.
Step 3 Change defaults setting
After load video files, you can now tweak various values that directly impact on the output result. Hit Option will open a window where you can trim, crop and add effect to the source video. Finally, check the box before Merge Files into One on the bottom of the panel, all the files can be merged into one then.
Step 4 Convert video
Hit Start, the entire list of source video will turn to your delivery format as you preset The time takes vary file and setting you have made..
Mar 19, 2009 | JNC Computers SSF-M636 Digital Media...
Problem with playing movies on my element GC-1020 model mp3 playe
when you put the mini-disk that came with your player into your PC, install the AVIconverter and it will allow you to convert certain video files into the ".avi" format, enabling you to watch videos that would otherwise be unplayable on it. there should be directions for this process in your users manual.
Dec 30, 2008 | Sears GC-1020 MP3 Player
Watching wmv files on DVd
MPEG-2 video is the file format you’ll need to convert to, but you cannot simply burn the MPEG-2 to a DVD and automatically play it in a DVD player.
The easily way is to buy software that will make the transition smooth; I recommend VSO Convert to DVD.
Nov 15, 2007 | Televison & Video
Open Questions:
I forgot my YAHOO password #{18OO~828O294} phone number usa Anita. There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. Please Read If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Oct 23, 2019 | Yahoo Computers & Internet
CHANGE password on YAHOO email account #{18OO~828O294} phone number usa Anita. There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. Please Read If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Computers & Internet Logo
66 people viewed this question
Ekse
Marvin
Marvin
