Question about Panasonic DMR-E80H DVD Recorder
Panasonic DVD Recorder
I have a Panasonic DVD recorder DMR-E80H that seems to be locked in this recovery mode. As I power it up, begins to reboot and then it says goodbye and turns off. I unplugged it and tried turning it on again, and the same thing happens. What causes this? I thought it to be the hard drive. brcause I fix PC's. Is this a common problem that can be easily fixed? I know it has a hard drive in it that is much the same as a basic PC has, but with an entirely different format. If it is a corrupted hard drive, I would think that it could be reformatted to correct any problems. There must be an OS on it that can be reinstalled I would presume. I guess I don't know much about DVD recorders compared to PC's.
  • Dennis Carey Mar 17, 2008
    There is no disc in it. As I try to power it up, I can see the disc indicator lite up. Then it says recover for a moment and then bye. After that, it just powers down. Most on the other forums say they had to replace the hard drive and it fixed it. They say that when they installed a new hard drive, it will prompt you to format it. I would think that if it had crashed, I would still have the ability just to reformat it.
    Guru:
  • 1,894 Answers
Sir there is nothing to do with the hard drive for this problem.
the player is going into safe mode every time you turn it oN.
this means there there some shorting in the circuit inside the recorder.
Posted on Mar 16, 2008
  • Panasonic Master
  • 19,396 Answers
Well does not work quite in that way. First there is a reset procedure , I will try to find out which is the reset procedure for your device
  • 1 more comment
  • Ginko
    Ginko Mar 16, 2008
    First check that you did not leave a disk inside, it can cause same problem.
  • Ginko
    Ginko Mar 16, 2008
    I think you reset machine to factory settings by pressing channel up and channel down at the same time . You will lose channels after this.
    I would exclude a short, when you have a short the machine usually do not say goodbay, just go off immediately.
    Can be a matter of settings or a firmware problem (this can be reflashed at service centre).
    Another cause can be a faulty or stuck in power button, check it out.
    Take also battery out from your remote next time you restart it. A faulty remote can cause a similar problem even if it is unfrequent.
  • Ginko
    Ginko Mar 16, 2008
    Here is user manual
    reset procedure is obtained by pressing ch up and ch down at the same time for a bout ten secs when in standby mode.
    You also need to check that there is no disk inside, if it does not open use the following procedure:
    With the power off, press and hold [stop(square symbol)] and [v, CH] at the same
    time on the main unit for about 5 seconds.
My DMR_E80H recorder does not read blank dvd-r disks
I don't have a solution but I am having the same problem (same model DMR-E80H). It will read finalized dvds but won't recognize or play blank or non-finalized dvds. About a year ago I had to replace the hard drive . . . I'm just assuming that the dvd recorder is just slowly breaking down and will need some kind of repair of certain components. (I think we bought it new in 2003/2004?)
Feb 13, 2011 | Panasonic DMR-E80H DVD Recorder
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
DVD Ram recorder
Mine, a Panasonic DMR-E80H, didn't like some of the Ram disk either. Either I was trying to erase it or just read it and it would shut it self off and go into recover mode.
So, I pulled the plug overnight. Then, first thing after I plugged it back in was to eject the disk before it tried to read it. Once the disk was out. It stopped going into recover mode.
Good Luck.
Dec 02, 2007 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-E80H Change Disc Error
If you haven't done so, try downloading the firmware update from their support site. Burn the update file to a cd-rom.
I have had numerous times where my unit recovered and I had to format the hard drive(losing all of my shows), but since I did the update this has not happened to me again.
Nov 26, 2007 | Panasonic DMR-E80H DVD Recorder
Remote control not working
Look into your manual that came with your dvd recorder for DMR-E80H, Page 46, Changing the Remote Control Code. My child played with a remote control as well and reconfigured it as well. In the manual, you have explanation how to configure your remote control again to work.
Nov 17, 2007 | Panasonic DMR-E80H DVD Recorder
DMR-E80H Remote stopped working
There is a section in the manual about resetting the remote. It is a simple fix You can go to the manuals on Panasonic.com to find the methods of the madness
Aug 08, 2007 | Panasonic DMR-E80H DVD Recorder
DMR E80H hard drive
DMR-E80H Hard drive problem seems to pretty common. My drive started making the famaous kerchunk noise tonight. After disassembly I see the drive is a ATA133 Maxtor drive....are you sure that you replaced it with the correct drive? I may contact Maxtor and try to get an RMA since the drive is only 3yrs old. Good Luck
Oct 09, 2006 | Panasonic DMR-E80H DVD Recorder
Need help to repair dvd hdd recorder
Repair is not cost effective but if you want to pursue, call panasonic or go to web site for authorized repair places in your area.
Sep 07, 2017 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-E80H DVD Recorder Logo
142 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
