Check your wires to make sure they're not crossed. follow them all the way back to the radio if you have to. when it comes to subs, you have to get it right with how you connect your possitive and negative especially coming out of the amp. if you have rca's connected from the radio to the amp, then check the output to your subs from the amp to the subs, make sure theyre wired correctly. if you used your stereo wires for input to your amp, then make sure those wires are positive with positive and negative with negative. also make sure you have them hooked up to rear output only. don't use one rear and one front.
