My subwoofers will only play at extremely low noise levels. They were playing fine and then in the middle of the song, the cut out, as if the power to them stopped, yet amp is working fine. If I turn down the volume all the way you can feel the subwoofers playing slightly. Answers?
Most of the time it's 2 things, first thing is a section on the PCB has burned out and this leave you with very little power going to your speaker, This is common by using incorrect wiring or peaking the amp all the time, You can start by pulling the PCB out and looking for any physical damage, If there is some you can solder a connection with copper wire. The second thing is blowing your finals, This happens when one side of the bridge for the PNP NPN transistor section blows out usually on the on position and this can send a dead short to your other final transistor. they will be in pairs of usually starting with A,B,C,D and a number grouping. This is next to impossible to fix.
