Question about Haier HWR12XC5 Air Conditioner
Dropped unit 4 months old. Dropped from about 1 ft and the circuit board/control panel cracked in half. Can this unit be fixed ? If so...approximate cost would be $________ ? Jamie jssims12@hotmail.com 678-262-6950
  • 86 Answers
5000.00 thousand indian currancy
Posted on Mar 17, 2008
Tv dropped
I'm willing to bet your LCD panel is now cracked apart from possible circuit board damage. Your only option is to probably replace the set. Either recycle the set or toss it on Craigslist as a parts unit.
Dec 04, 2012 | Vizio L32 32 in. LCD HDTV
Remote control
Remotes fail for about 4 different reasons and most can usually be fixed:
1. batteries bad or cause rust etc on contacts, or contacts do not hold batteries tight.
2. Liquid sometimes gets spilled on front where the buttons are--it is a one piece mat and if liquid gets under the buttons do not work or some do not work.
3. Remote gets dropped--usually this breaks a connection or part loose from the circuit board inside.
4. Remote not programmed for unit being used on.
different approach for each---which describes your problem?
The remote can be tested by any shop to see if sending a signal or not.
Nov 08, 2012 | Televison & Video
My son dropped my 32'' inch LG lcd tv now it won't
It probably has a cracked circuit board. If you want to repair it on your own open it up and see if you can find where that cracked section is and see if you can resolder it back properly.
May 28, 2011 | LG Televison & Video
Dropped unit from about 3 feet on driveway. cannot start now
Check for spark. I dropped one once, and it turned out to be a cracked spark plug electrode.
Best regards, --W/D--
Jul 25, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
No audio, scroll knob not working.
Dropped BC246T fix:
Open up the back of the scanner (6 screws-2 in the battery compartment and 4 on the outside of the case). There are 2 circuit boards inside joined by a connector which can be dislodged just enough to break contact if dropped. My unit seemed to partially work because apparently one board is logic and the other controls reception. Anyway, gently push the top board into the bottom one and that should fix the problem. The connector is located towards the lower right part of the circuit board as you look at the unit with the back off. If this doesn't fix it you may need to loosen the screws to the top board and make sure you have the connector alligned properly-it made it easier for me to know where to push.
By the way-do i get paid for my solution by fixya.com as your 'experts were going to charge me a fee??? Just wondering..fair is fair you know : )
Hopefully this will help someone else with my problem.
Jun 23, 2009 | Uniden BC246T Handheld Scanner
The Wii console is not powering up at all.
Hi there, this is a power board failure. It seems to be a manufacturing error considering the fact that, this Wii is only 2 months old. i would excercise the warranty if possible and return for exchange. this is a defective unit.
Feb 18, 2009 | Nintendo Wii Console
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
LG Plasma 50PC5D Help
sounds like the internal screen has cracked look closeley to see if you can see any cracks if so new screen im affraid if no cracks suspect power board
Mar 20, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sony trinatron dropped!
If you dropped the set you have probably cracked the circuit board around the Fylback transformer or other places on the board. You should get a technician to look it over.
Dec 27, 2007 | Panasonic PT-51G35 51" Rear Projection...
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Heating & Cooling Logo
70 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
