Question about Kitchen Ranges
My 48-inch Viking gas range is making a high-pitched, continuous, whining noise (not a beeping). It has never done this before.
  • 2 more comments
  • Anonymous Mar 22, 2008
    Our electrolux dual fuel range does the same thing a high pitched noise that won't shut off even when the breakers are down. Any thougts?
  • akw9 Aug 29, 2008
    Just bought a new Frigidaire range. It also whines when the stove top is used, and depends on how high we turn up the burners. I don't know what to do to fix this!
  • brumley Sep 08, 2008
    Oops, sorry to post under the solutions. My new Frigidaire is doing the exact same thing...
  • rlgrot May 18, 2009
    New Viking range. Burners make a whinning noise when lit.
Anyone figure out what the fix for this is??? I just bought a new frigidaire and it's doing the exact same thing!
Posted on Sep 08, 2008
Continued battery drain and high pitched noise when car started
Maybe the alternator is bad. A high pitched whine could mean that the alternator is not working properly.
One can test, by removing the belt to the alternator and running the engine and seeing if the whine goes away.
Jan 16, 2011 | 2000 Toyota ECHO
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
Oct 20, 2009 | 2003 Toyota Sienna
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
Apr 15, 2009 | Viking VGSC306-4B Gas Kitchen Range
Dryer makes a whining noise when drying
The belt is not the problem but more likely the drum rollers or drum bearing will need to be replaced.
Jan 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Whining noise from freezer
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
Electrolux dual range has a high pitch sound. Shut breaker down to stop the noise but it continued. Any suggestions?
its electricall disconnected nad your still getting a high pitched sound???? that would only leave your gas connection as the culprit
Mar 22, 2008 | Kitchen Ranges
Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
Nov 21, 2007 | Viking VGSC366-6B Gas Kitchen Range
Kitchen Ranges Logo
426 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
