Question about Proscan 19LA25Q 19 in. LCD Television
Problem with proscan 19LA25Q
My TELEVISION IS ONLY 8 MONTHS OLD. I HAVE IT CONNECTED TO MY COMPUTER TO SERVE AS A MONITOR AS WELL. tHERE WAS A SLOW BUZZING SOUND COMING THROUGH THE TV SPEAKER FOR ABOUT 40 SECONDS. THE PICTURE DISAPPEARED FROM THE SCREEN, GRADUALLY IT WENT FROM TOP TO BOTTOM. NOW THE RED LIGHT STAYS ON AND I CAN'T POWER UP THE TV. PLEASE HELP.
THANK YOU
  • gene3034 Apr 29, 2008
    seem like everybody has the same problem with not being able to turn tv back on i need the # of this comp or site. thanks
  • Anonymous Jun 29, 2008
    connected ps3 red light just stays on no power
Watching a movie tonight...and slowly there was odd behavior from the screen. No volume at first, then flickering, fragmenting and now, as the others only shows the red power. I have noticed some strange flickering the past 2 weeks or so. I thought it may be the cable, so did not concern myself too much. I believed that was the problem tonight as well. But the screen is definately not responding to the remote or manual button.
Thanks
Posted on May 18, 2008
How do you play sound on a BenQ PC monitor with VGA no Audio Cables For a HP Proliant microserves Gen 8, I need help
it is a server not a PC, so no sound jacks there.
if you do see 3.5mm line out jack green there'
then it does have sound. easy no? or optical jack.
One can be added, in most or all cases.
If you look at the drawing in the manual here,its missing.
note lack of server sound jacks?
3.5mm or the like.
/9da35884-da52-49e7-ad7b-cf3fc44493be.jpg
Dec 31, 2017 | HP Computers & Internet
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
32me402v Magnzvox
If the set is still under warranty period, use it. The main power supply regulator board had the fault.
Jun 28, 2013 | Magnavox NEW 32ME402V BLK 32" LED TV 1080P...
94 dodge caravan wont start
Check your connctions, it may mean crawling in and seeing if you have a loose wire on the starter. Sounds to me like a bad connection.
Nov 14, 2012 | Dodge Cars & Trucks
There's a buzzing sound coming from our RCA Scenium tv, how do we fix it?
Are you using RCA type audio cables?, if so, make sure the connectors are tight and the cables are not frayed, it also helps routing those analog cables at least 8 inches away from any power cords or transformers. Buzzing usually is caused by loose ground connections or RF interference.
HDalacarte.com guy, audio/video/computer technician for over 30 years
May 26, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a 25" Hannspree monitor which is only about
No - the buzzing you're hearing is probably the inverter transformer. Its' purpose is to generate high voltage to turn on the backlight to display the image on the screen. The monitor should still be under manufacturers warranty since most of them are a year. Have it repaired or replaced.
Feb 14, 2011 | Hannspree HH251H 25" LCD Monitor
Buzz coming from speakers. x2 gen 19 inch lcd been working for 2 years on old xp and now win7 no problem with win7 for 4 months before this. checked for updated sound drivers. plugged in usb powered...
Buzzing is usually caused by bad audio ground connection. Try insert and reinsert the audio cable first. It can also be the sound card. Try using the MP3 player as the sound source feeding the monitor, if it still bad then it can be problem in the DC filter caps in the power supply, or bad sound IC in the audio board inside the monitor. Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
May 07, 2010 | X2Gen MG19VT 19" LCD Monitor
I have a 4 month old Dell Studio 1535 laptop, with audio problems
Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
Check the microphone and try to play music again.
Please post back
Good luck.
Oct 02, 2009 | Dell Studio 1535 Notebook
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Can't get LG desktop to communicate with monitor
connect the monitor to the PC and restart the computer. Make sure your keyboard doesn't have any stuck keys.
Dec 20, 2007 | LG Studioworks 700S 17" CRT Monitor
Proscan 19LA25Q 19 in. LCD Television Logo
167 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
