Question about Epson Stylus RX500 All-In-One InkJet Printer
HORIZONTAL BANDING IN MY PRINTS
I've recently discovered horizontzal banding, (left and right across the 81/2" width), in my 81/2 x 11 prints. It's most apparent in the lighter tones. I've done all the nozzle cleaning and head alignment to perfection. The problem is the print head alignment,(here on refered as P.H.A.), operation indicates that it is addressing the Vertical lines and banding, not the horizontal lines. Am I missing part of that procedure somehow. I have an Epson C88 at work and the P.H.A. does indeed have an additional operation that address the horizntal banding specifically. My RX500 has done a faithfully great job since I got it in Dec.2004 and I did have to override the "ink pad saturation point shut down" about 8 to 10 months ago. Can you tell me anything? Is it time for a new printer?
  • 1 more comment
  • Anonymous Jan 26, 2009
    I am having the same problem except it is only when printing black. Anything in color is fine. Someone suggested that I use only Epson cartridges for the black. I tried that and it still prints with horizontal lines through anything printed in black and white.
  • richpetocz May 11, 2010
    Hi gwbm,
    First let me give you my most sincere apology for not getting back to you months ago. I had bought a new computer and have had to focus on all the resetting up of some older version image editing programs into my new O/S, (Vista Home Premium SP1 64 bit, an absolutely great system, far better than my Windows XP O/S). I fell behind on a lot of things and I did try to contact you through fixya but was having a problem with it. (That's another story though). The truth is that this problem with my RX-500 has been taken care of. Mostly the problem came down to head wear. I'm a photo-artist and I have had this printer since December 2004. I will gamble a bet that I put my printer through far more than most home use printers. Not only does this printer produce hundreds of 8.5 X 11 colored prints, (always in the 'Best Photo' and 'no high speed' mode), at an AVERAGE rate of 100 every month and a half, but it typically must print on high ended, Coarse Textured, 100% cotton rag papers as well as a regular line of high end Canvas's. I didn't quite understand why you thought I had been referring to the C88, (that one is a cheap company computer in my office), because I did ask my question in what I thought was an RX-500 forum, ("I thought"), and I did mention that it was an RX-500. But all of this said, my problem was a very pronounced horizontal banding that, aside from head wear, was made worse by some dried, cheap, ink, (I was using a less expensive off brand back then). I read the sollutions you recommended and I beleive that if it happens again I'm going to try it. It may save me a lot of wasted ink like I had to go through in the head cleaning processs back then. Again, thank you for your trouble I hope you understand and because I beleive that your recomendation would have worked, I am going to score this with a "FixYa!" Rich P
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi Guest - I presume you are referring to an Epson C88. I don't know if you will see this, but we need a bit of an interactive session to help you. Can you register on FixYa and post your own query?
  • 353 Answers
OK Guest - I'm sorry you aren't prepared to respond, so here's the best I can do without it.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Mar 01, 2009
SOURCE:
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Pages printed with dark horizontal lines the entire length of the page with a repeating (lighter) images.
I have seen bad laser scanners cause this...
A black line across the page from left to right, of various widths, at various intervals, all the way down the page.
First, though, I would reseat the toner cartridge. If the problem disappears, you are in luck!
Try another Toner Cartridge to see if the problem disappears.
It could also be a bad control board.
Good Luck.
Nov 03, 2010 | HP LaserJet 2420 Printer
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Apr 26, 2010 | Zebra Stripe S600 Thermal Label Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
May 13, 2007 | Konica Minolta magicolor 2300DL Laser...
Epson Stylus RX500 All-In-One InkJet Printer Logo
500 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
