Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
Ariston al1256t bearing replacement
Need to put new bearings into drum but need to remove drum first how do you remove the drum we have undone all bolts the drum wont come out the top or the bottom , the pulley wheel wont come off can you help thanks
  • Anonymous Nov 25, 2008
    I also need to change new bearings into the drum. My machine is Ariston Margherita 2000 AB95, but I have the same problem - pulley bolt is so tight that I can't get it out. What should I do? Is it even possible to open it? Is the screw thread "left handed" i.e. screw opens clockwise, when usually screws are "right handed" and open counter-clockwise?
Lay the washing machine on its front & remove the back cover. Loosen the motor mount bolts (2 only) to allow the drive belt to slacken. Sit the drive belt aside. You will notice that the belt goes back into the clean shiny grooves in the motor pulley - be sure to put into the correct grooves when reassembling.
The drum pulley centre bolt is a normal right hand thread ie clockwise to undo. The pulley is then easily removed with a bearing puller.
Loosen the three bolts on the end of the 3 pronged mount, noting which is at the top of the machine - it only goes in the one way. Remove the three pronged mount from the machine. It will withdraw fron the drum shaft easily - worst case use the bearing puller again.
Next knock each bearing out of the three pronged mount with a drift, being careful to not damage the seal on one side. Put new bearings in (with 2RS seals are ok instead of 2Z type ie plastic seal is ok in place of metal seal for these bearings). Refit the seal last of all.
Put all back together & retighten the bolts firmly. Fit the drive belt (in the motor pulley shiny grooves) and retension the belt with the motor mount bolts (2 only) back in the original position.
Don't forget to put the machine back upright before test running!
I have also rebuilt a motor in one of these for about $100 if anybody needs to know how. Much better value than replacing one at $375+.
Posted on Aug 03, 2010
  • David Richards Mar 03, 2012
    Oops! typo error in second paragraph - right hand threads undo anti-clockwise!
Hi
I just did this on a different model - it is a normal (right-hand) thread
This is best done with the machine lying in its front.
1 - If it's a Torx screw (probably a T40), buy a torx bit for a rachet spanner - Halfrauds do them for about a fiver - you may need an adapter as well if your rachet is 1/2 in drive. This is far better than using a bit in a screwdriver handle.
2 - Heat the pulley around the screw (careful use of blowlamp) as it's fitted with thead lock compund and this helps to soften it.
3 - If that doesn't do it, try a cold chisel and hammmer to knock it around - you need to break the thread lock initially. You might need to replace the bolt after this :-) and you need to be careful not to break the alloy pulley.
4 - If after removing the screw the pulleyt doesn't come off, try heat again and wiggle it off rather than a straight pull.
Bear in mind that after removing the pulley spider, getting the old bearings out and the one ones in is also best done with gentle heating and is not a trivial job.
Use blue thread lock compound when reassembling as this will come off easier next time.
Whole job, start to end took me took 3 1/2 hours
Ricko
Posted on Dec 14, 2008
How to change noisy bearing on Ariston AQXXF 129
inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
Aug 25, 2014 | Ariston Technologies Washing Machines
Exacly how to remove rear brake drums ? 2001 Ford Focus SE. I don't want to remove the hub & spindle. I simply want to replace the drums & Brake shoes.
The drum and hub are one assembly on that vehicle so you will need to remove the dust cap in the center of the drum and remove the large axle nut. The drum/hub/bearing assembly will then pull off of the spindle.
If you want to replace the drum you will either have to find one with a bearing already installed, Have your old bearing pressed out of the old drum and pressed into the new drum, or have new bearings pressed into the new drum.
When installing the new drum it is very important to tighten the axle nut to the proper spec. I can get that spec for you if you need it.
Apr 06, 2011 | 2000 Ford Focus
Noisy Washing machine drum
To replace bearings is quite a job. iyf your good at diy i rate this as a 9/10 ....A bearing kit is available from makers and instructions.
Apr 03, 2010 | Ariston Technologies AWD120WH Ariston
My ariston intergrated washing machine''s inner drum has dropped and is making alot of noise, it seems to be detached and ''loose'' from the outer drum casing
Either the main drum bearings have collpased, or the drum support has corroded and fractured, thus causing the drum to collapse.
It is a major repair, and quite expensive to put right.
In my experience. I think you would be well advised to consider replacing the washer.
Please rate my solution.
Thankyou.
Jan 24, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Hotpoint WMA48P bearing replacement
REMOVE THE POWER PLUG FROM THE SOCKET
this is a messy job, you will need to remove the lid remove the front of the machine 2 -3 screws behind the clip on pannel front bottom I cant rember if the front hangs on two lugs one either side or if there are acouple of screws behind the faceplate, you will need to disconnect the door safty switch (make note of the wire positions), remove the wire band that clamps the door seal to the outer drum, now you should be able to see the drum and the drum outer casing, you will neeed to remove the access panel from the rear of the machine and if the belt has not already come off remove it , you notice a large nut holding the flywheel on inspect closely as there may be some securing tags (large washer with folded edges stopping the nut from comming undone ) remove nut , you will now need to remove the drum from the front of the machine using a peice of wood place on shaft and strike it with a heavy hammer or a mallet do not worry about damaging the shaft as you will need to replace this as well as the bearings as when bearings fail it is normaly to do with water getting to the bearing and corroding them (rust) untill they give up this normally damages the shaft, once the shaft is removed if you look through to shaft hole you will see the outer casing of the beaings thease need to be removed normally by tapping out (not always easy)there are two one at fromt one at back the back one is removed from inside the drum front removed from rear of machine , once this is all clear you are ready to the reverse putting it all together, the bearing kit should contain all you need to replace the bearings including the spider ( the three legged fitting that connects to the drum and has the shaft on it) when replacing the bearings make sure that where the old bearings come out of is nice and clean (fine sanpaper to remove small high spots) i use vaselene to aid bearing seating , using a rubber mallet genlely tap the edge of the bearing into place (never hit the center of the bearing as you could damage the seal and or the bearing) when the bearings are in smear some grease onto the shaft and rfit, a bearing kit trade is about 20 uk pounds
Jan 15, 2010 | Washing Machines
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
Hi, My name is Atanas, I am trying to change bearings on our Ariston avd149. I just found out it is not possible to get out the inner drum. How do I support the inner drum with the axis when putting the...
I needed mostly advice on how to put back in place the shaft of the inner drum in the bearings without using a hammer... Now I found solution on this- just use a screw bolt. Hope this works…
Thanks
Nov 16, 2009 | Ariston Technologies AW 149 NA
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Drum Bearings replacement
This is Mogsey above, I have now renewed the bearings in my Zanussi Jetsystem 1600, Model FJD1666W. Had a man in to help. It really is a two man job and I put my back doing this with him. The bearings were much larger than previously encountered. Very! basically you have get out the residue water, release the door seal and (pipe attached) spit the m/c casing, unclip all hoses attached to drum, unclip all drum wiring ,remove belt (note position) remove motor &, lay to one side, withdraw nylon pins from shock absorbers, Look for and remove the little earthing cable set just inside the pulley rim. Carefully release drum/case supporting springs (mark positions top and bottom) and, drop drum/case onto some blocks and lift/pull/take out (really needs two people) (minding other modules). Split drum/case ring of bolts, remove front half (careful here not to damage the heater). take half containing drum outside, lay drum face down and use a drift to hit the socket headed screw securing pulley hard to shake up the taper. Remove this screw (needs good quality allen key) and use wedges to the force off the drum drive pulley. Support drum casing on blocks or put drum on its side, support the drum if on its side and use a heavy drift and hammer to knock through the drum spindle. Careful now to avoid grating hands on the sharp drum holes. With drum now removed place the casing drive end up (ensuring protuding heater is clear of the ground!) put a large bolt (head down) inside the first bearing and rest it on the edge of the inner bearing. Carefully working round the inner bearing edge use a hammer and the bolt head as a drift to knock out the inner (the larger of the two bearings and inturn the drum seal) (note seal postion). Turn over the casing and knock out the outer bearing from inside the drum casing. Clean all and check condition of spider/spindle & renew if damaged. Fit the new outer bearing then the new inner followed by the seal. Dig out the old and renew the (green) O ring seal between the drum casing halves. Replace all, but give a quick test run before replacing casing to ensure belt is positioned correctly. The job would have cost £115 which I think is well worth paying someone to do.
Dec 02, 2007 | Zanussi FJD1666W Front Load Washer
Washing Machines Logo
890 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
