Print massage Used Ink Cartrige Full what do I do to fix this????
  • 24 Answers
What is your problem?
Posted on Mar 16, 2008
When i print pictures, the pictures print shuters and i dont know how to fix it
  1. Check the ink cartrige or toner cassette, because the problem could be caused by lack of toner or ink.
  2. If your printer is InkJet - some of the color cartrige's nozzle could be clogged. You can choose to buy new one or to put the cartrige in warm watter to unclog the nozzle, but you have to be careful.
  3. Try to change DPI and check if there is a difference between the copies.
Dec 02, 2011 | Epson Office Equipment & Supplies
Will the Epson cx3900 print if one of the coloured cartrige is empty
No unfortunately the printer will not print unless all cartridges are present and have an adequate supply of ink inside them. Even if your only printing black and the black cartridge is there and full, it will still need the color cartridge ot be present and partically full of ink in order to print.
Aug 15, 2011 | Epson STYLUS CX3900 All-In-One InkJet...
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Cyan ink cartage does not work in epson t11 plz tell me what can i do. lllllll;htgg;lp gkjhjjhkljkljkljiokggyu0ijhgjhpjnp[to[otto
Jast push some ink through the print head plastic pipe.Take a seringe of full ink, put off all the ink cartrige, then set the seringe front hole on the cyan black pipe (that are usually set in side the cartrige). Then push cyan ink into the pipe.
After that, I think your printer would work again.
Thank you
shohagtush
Oct 27, 2010 | Epson Office Equipment & Supplies
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
Printer was off for a week and when turned on indicates "incorrect black cartrige installed"
Use lint free cloth and clean the contacts on cartrige and contacts on printer were the cartrige gos in. Be very gentle and very careful do not damage the contacts. Reinstall the cartrige an try again to get it to print. Do not touch the inkjet on the bottom of the ink cartrige it may distroy the print head chip on the ink cartrige and make it useless.
Sep 16, 2010 | HP PSC 750 All-In-One InkJet Printer
This printer has not been used much since it was purchased 4 years ago. The black ink will print/copy, but misses about 2 lines in an alternating pattern. I'm new to this machine. Have cleaned heads,...
Ink cartridges don't do well when you let them stand for long periods. The ink dryes up on the print head. Try taking out the cartrige then take a damp paper towel with hot water (microwave works great for heating it up) draw the print head over it several times until you see ink flow evenly. them take a dry paper towel and draw the in head over it the same amount of times and reinstall. If doesn't solve the problem you may need to replave the cartridge.
Sep 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
I haven't used the printer in a while (about 6 months) then last week I turned it on and tried to use it. Went to print a test page and it went through the process but nothing came out on the paper. I...
Take out the cartriges and hold one at a time between your forefinger and thumb tightly. Hit your wrists together and see if ink comes out the bottom of the cartrige. Be careful not to mess ink on your clothes or carpet etc. This sharp "shock" will bleed the cartrige and hopefully the cartrige will work. Clean all messed ink from any contacts and the jet area of the cartrige before inserting back into the plotter.
Dec 14, 2008 | HP DesignJet 750c plus InkJet Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
