Question about Gateway FPD2275W LCD Monitor
Proview 15" tft screen vga cable
I have a 15" tft screen.
I need a replacement vga cable for it.
It is not a convential cable it has a 15 pin socket one end and a small white plastic plug the other.
I have E-mailed proview with no response what's so ever.
I have googled and nothing.
I know this is an old screen but it worked great.
Please help
  • mini76 Mar 17, 2008
    Model no. is bm 568
    this is an obsolete model.
    Someone must have one of these leads.
    Would I be able to buy a normal lead and cut the end off and join the wires together.
PA 448 vga cable
Posted on Sep 04, 2010
  • Iguana5 Dec 27, 2011
    Where can I buy this replacement cable I have a old proview monitor 17'' BM 780
Its very easy to fix this problem. The 1st step that you must do is get the old monitor that you have and perform a FUSION-HA technique, then! 2nd step you must focus all your ki power and ascend to level 3 before performing the Kio-Ken and Super Kamehameha on your old monitor....I hope this this is usefull. Thank you
Posted on Sep 25, 2008
I Have the same screen for sale item no.300215403733 on ebay. Thanks
Posted on Apr 14, 2008
So if I take a VGA Cable from a CRT montitor and swap out the white 28 pin female connector from inside the monitor while matching the pin wires to those listed in your last post should it work?
Posted on Apr 02, 2008
Model ?
e-mail ?
I have !!
Posted on Mar 17, 2008
  • Raimundo Alencar de Souza
    The pin numbers are for the 15 Way HD connector.
    Coax, RED centre wire: Pin 1
    Coax, GREY centre wire: Pin 2
    Coax, BLUE centre wire: Pin 3
    Black: Pins 4,5,6,7,8,10,11 & sheilds (inc. Coax)
    Pin 9 is meant to be missing!
    Grey: Pin 12
    White: Pin 13
    Yellow: Pin 14
    Violet: Pin 15
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
How can i connect my advent qrc430 to a hd television
There are two options available with this laptop. Unfortunatley you will not be able to produce a High Definition picture, but nether the less it is possible to connect it to a HD TV.
The connections available are;
1x VGA - You will need a VGA Cable (as long as your HD TV has a VGA/PC input) cheapest found on Ebay. There is also a VGA to HDMI cable. Still wont be HD but an alternative to think about.
1x S-Video (TV-Out) - You will need a S-Video Cable (make sure HD TV has this input) also cheapest on Ebay.
Both of these options do not produce audio through them so for this you will need a 3.5mm audio jack to 3.5mm audio jack. Plug one end into your earphone socket on your laptop and the other end into your HD TV PC Audio in socket/Audio in socket. If you have a Cinema/surround system you will need a 3.5mm audio jack to stereo phono, as long as the surround system has an audio input.
VGA to HDMI cable:
3.5mm AUDIO to 3.5mm AUDIO:
3.5mm AUDIO to PHONO:
Hope this helps. If it does please leave a thumbs up....Thank you.
Feb 04, 2010 | Computers & Internet
My monitor does not work right. it says vga not support.. its a proview 17" matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
hope that helps,
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
the vga mode not suppopt is on and not working
May 07, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Feb 29, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Need new power cord
Elizabeth, I poked around last night but couldn?t find an absolute answer to your question so I didn?t post an answer. Since no one else has answered it I?ll share my best guess. Your monitor probably uses a standard 110v power cable. Take a look at your power socket on the monitor and compare it to this picture on Ebay and chances are good the socket end will match your monitor. Your video cable may be a little trickier. Assuming your monitor and your computer video card both have standard 15 pin VGA sockets (?D? shaped connector about 1? long with three rows of little holes) this cable listed on Ebay or one like it will work for you. If these don?t match the connector ends on your monitor let us know, and as always please don?t forget to rate this posting.
Feb 22, 2007 | Proview PL576Ws 15.4" Widescreen LCD...
Gateway FPD2275W LCD Monitor Logo
508 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
