Buzzer instead of radio
On goodmans dab clock radio with ipod dock(gcr1872dab) when alarm is set to radio buzzer sounds instead
any suggestions?
  • jess49han Apr 12, 2008
    thanks for your help.
    not ideal solution but i also got this from goodmans after 3rd try.
  • simonf1956 Jun 30, 2008
    I have the exact same problem. Did you get a solution?
I have this radio too and from what I have read in a review on amazon suggests alarm does not tune to DAB only FM - very annoying! Contacted Goodman customer care and they suggested it was a problem with a component but maybe it is just the design.
Posted on Apr 11, 2008
SOURCE:
I need the user manual for an alarm clock called clok. I can't set the time or radio stations
These steps will only work while your unit is OFF. The power button is located at the top left face of the unit.
How to set time?
1. With the unit OFF, press and hold down the Clock/Display/Play/Pause button for at least 5 seconds.
2. While still holding the Clock/Display/Play/Pause button, press the Hour, and then the Minute button to adjust the hour and the minute on the time.
3. After selecting the correct hour and minute time, release the Clock/Display/Play/Pause button to set the clock.
How to set the alarm?
1. With the unit OFF, press and hold down the AL1 or AL2 button for at least 5 seconds. (an alarm icon will flash on the lcd display)
2. While still holding down the AL1 or AL2 button, press the Hour and the Minute button o adjust the hour and minute on the alarm time.
3. After selecting the correct time for alarm, release the AL1 or AL2 button to set the Alarm time.
4. Press the AL1 or AL2 button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio or a docked iPod.
Apr 17, 2011 | Audio Players & Recorders
How do you set the clock and alarm on the Starlite Next Play Clock Radio with iPod Dock NP105CR
Setting the clock for the Ipod docking station
NP105CR
Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
866-387-2027 for manual
Jun 23, 2010 | Starlite Next Play Clock Radio with iPod...
Lost my manual how do I turn off the alarm. If I don't want my alarm set.
Press the SET button to highlight which alarm (1 or 2) when it flashes press the function button up to 4 times to roll through the settings for which alarm you want to go off - IPOD, radio, buzzer. The fourth is OFF and OFF will start flashing. When OFF starts flashing, then stop and do not do anything for 5 seconds. Then the alarm setting of OFF will be intact. If you put on BOTH alarms, you will need to do this with alarm 2 as well. When you get back to the time if you have done it right, no alarm mode will be showing.
Jan 24, 2010 | Starlite Next Play Clock Radio with iPod...
I have lost he instructions for my Ministry of Sound hi-fi with docking sysytem and don't know how to tune the dab radio...can anyone help?
plug it and with power on but don't turn the station on, leave it in standby mode. then press and hold mem/set on your remote. then set the hour and press mem/set to move onto the minutes. when done press mem/set again and your time is sorted.
May 31, 2009 | Sony STR-D600SS Shelf System
Alarms
[http://www.emersonradio.com/owners/iPod%20Series/iC200_NCab050307.pdf] Copy this web link and paste it into the address bar of your browser. It will take you to the Emerson customer support web page of a pdf copy of the owners manual for your Clock/Radio. You can use the print function to make a pdf copy of the manual for your own use. To increase the sound of the buzzer in the alarm you will need to exchange the internal battery for a new battery. The buzzer works on this battery power alone. The model of the battery (CR2430) and how to replace it are in the owners manual on pages 41-44. If this fix doe not solve the problem you are having with the weak buzzer. You can call the Emerson customer support at this telephone number 1-800-898-9020. Between the hours of 9am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you with the problem of the weak buzzer sound on the alarm of your Clock/Radio.
Mar 10, 2009 | Emerson Smartset Clock Radio
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected] It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
Setting the clock?
select the slide on the top to set clock, then use minutes and hour buttons to adjust accordingly, slide to alarm and repeat, press set button if no slide, also, have alarm set to buzzer/radio accordingly, and alarm 1/alarm 2 accordingly if applicable.
Oct 20, 2008 | Audio Players & Recorders
624 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
