Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
Ram support hi i have this motherboard and i would like to make an update can you please make a list wich ram my motherboard supports? thank you for your time
    President:
  • 2,351 Answers
As much as I would love to spend a couple hours making you a list of Ram that your board supports, not happening.
However you can do this your self by looking in your manual.
Download your manual here:
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1863
Go to the top of page 15.
Your board requires a voltage of no more than 2.5v
GA-8IPE1000 Series includes 4 DIMM sockets, and each Channel has two DIMM sockets as following:
Channel A : DDR 1, DDR 2
Channel B : DDR 3, DDR 4
If you want to operate the Dual Channel Technology, please note the following explanations due to the
limitation of Intel chipset specifications.
1. Dual channel memory cannot be used if one DDR memory modules are installed.
2. If two DDR memory modules are installed (same storage capacity), one must be added to the
Channel A slot and the other in the Channel B slot in order to use dual channel memory. Dual
channel memory cannot function if both DDR memory modules are installed on the same channel.
3. If four DDR memory modules are installed, please use memory of the same storage capacity in
order to use dual channel memory and for BIOS to detect all the DDR memory modules.
We'll strongly recommend our user to slot two DDR memory modules into the DIMMs with the same color in
order for Dual Channel Technology to work.
You board supports this type of memory:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-16
Or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1717669&CatId=1352
Good Luck & kind Regards.
& please vote.
Posted on Mar 17, 2008
Complex number
Zi = 5 + 8i
Posted on Apr 09, 2008
Will the Intel D945GNT motherboard run Windows 64 bit OS, and will I need to change the RAM. At present I have Two Transcend 512 MB DDR2 Mhz modules on it. Please advise. Thanks.
Trying to run W7 64 bit with only 1gb of ram will make the system really slow. I suggest you purchase 4gb of PC5300 (667mhz) of ram which will cost about £30. Your system will then fly compared to what it is doing now.
Sep 17, 2011 | Intel D945GNT Motherboard
I have same problem. this cpu is no supported by this model" im update my bios but same problem is going on. what can i do :(
Hi, you can take a look at this site:
http://uk.asus.com/Motherboards/AMD_AM3/M4A78LTM_LE/#CPUS
This is the cpu list that your mainboard supports.
Remember the ram module have to fit the cpu also.
Hope this will help you.
Aug 11, 2011 | ASUS M4A78LTM LE Motherboard
Hi Could you please advise the type and size of
According to the manual, to max out the board's RAM you'd need to install 2 1GB sticks of DDR RAM. It can support DDR400/333/266. 2GB is it's maximum capacity.
Jul 09, 2011 | Intel Motherboard
I have P4 2.66Ghz processor, D101GGC motherboard, but this motherboard support DDR RAM, so I want to upgrade my Motherboard which support DDR2 RAM, please help me
This motherboard only Support DDR RAM.
It will not support DDR2 RAM.
So, you have to buy a new one.
Thanks for using FixYa.
May 24, 2011 | Computers & Internet
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
D845gvsr mainbord waht kind of menory dos it use? how nuch at max? instaale in wich or the theree slots
DDR ram will have to be installed on this motherboard. and this board can support upto 4GB RAM. and if you have more than one RAMs then make sure all the RAMs have same bus speed.
Oct 04, 2009 | Intel Motherboard
I have a Gigabyte-GA-8SIMLNF motherboard and recently bought 2gb (2*1gb)of pc2100 DDR and am getting the no ram beep,it is labeled ecc ramwill this not work?
Your motherboard does not support ECC RAM. You'll have to buy a PC2100 nonECC DDR RAM. Also, it supports a maximum of 2 GB RAM, i.e; 2 RAMs each of 1GB in each slot.
Hope this answers your query. Thanks.
Jul 22, 2009 | Intel Motherboard
Sata drivers for my mother board
Hello there.
Click here to download drivers for your Intel based motherboard.
You need to choose your version of Windows from the list to continue.
Hope this helps.
Jul 19, 2008 | Intel Motherboard
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
339 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
