My recently bought laptop is not charging.i replaced the battery but still the same problem. i restored the system but still the same. i guess the problem is with the hardware.
  • 655 Answers
Yaa, its sounds like serious hardware problem.
You should not try to fix or change the battery, atleast you have one year warranty. You shuold go to vendor and give him for replacement.
Thanks
iqbal
Posted on Mar 16, 2008
My acer travelmate 8210 won't turn on
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
Disconnect accessories plugged into the computer, such as the printer or mouse, and try restarting it.
Start the computer in "Safe Mode" or use the "Recovery Console" if your laptop is able to get past the initial start-up phase when you turn it on, but does not get much further than that.
Doing this will allow you to get to your main screen, but you will have limited access to certain drivers and start-up programs.
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue
Run "ScanDisk" and other diagnostic tools to see if your can computer find what the problem is and repair it on its own, as the Indiana University's website recommends.
Sep 06, 2013 | Acer TravelMate 8210 Notebook
Upon Pressing the power button, the computer Power LED light is lit, the hardrive light powers blinks, and then stays off. Screen is black, not response at all. Proceeded to connect the laptop to an e
Below are steps that can be taken to help identify the cause of this issue. Leave power plugged in
Removing it and then put it back into the laptop. Third-party utility Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery. Disconnect accessories plugged into the computer, such as the printer or mouse, and try restarting it. Start the computer in "Safe Mode" or use the "Recovery Console" if your laptop is able to get past the initial start-up phase when you turn it on, but does not get much further than that. Doing this will allow you to get to your main screen, but you will have limited access to certain drivers and start-up programs. restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and work your way through the problem if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue Run "ScanDisk" and other diagnostic tools to see if your can computer find what the problem is and repair it on its own, as the Indiana University's website recommends.
Feb 04, 2013 | Dell Inspiron Computers & Internet
S42ax-yb04 ne s allume pas
google translated French
s42ax-s do not turn yb04
s does not light
post a reply with more details
Feb 04, 2013 | Computers & Internet
Power light blink orange 4 times, 1 green?
My guess is that the battery is worn-out -- no longer accepting a charge, nor holding a charge. Replace the battery, or find a specialty business that "refurbishes" batteries (by opening the case, replacing the cells, and re-sealing the case).
Mar 04, 2010 | Dell Inspiron 6400 Notebook
Total battery power remaining: Unknown
Well you can try a system restore.
1.) start
2.) programs / accessories / system tools
3.) system restore
follow the on screen instructions too restore the computer to a few days before it started having problems.
Chances are that the battery is shot if system restore fails.
Mar 01, 2010 | Acer TravelMate 5720-6635 Notebook
A few months ago my Dell Vostro 1500 laptop started saying that my battery could not be detected. I bought this laptop new in October 2007 and did not extend my warranty. I bought a new battery and...
Normally the message means that the battery is bad and needs to be replaced. There is a chance the new battery you got was defective and went bad before its time.
The motherboard can be the problem, although it is not common for this to be the case.
I would try one more battery before thinking about a new motherboard, a new battery is under a $100 where a new mobo is several hundred, and usually this is a sign of a bad battery. If you disconnect the ac adapter and it stays on then it is using the battery, although it is reporting that it cannot see a charge. I would guess the battery malfunctioned and is not being able to be read by the laptop.
Sep 12, 2009 | Dell Vostro 1500 Notebook
HP Pavilion 1221 TX Battery Problem
You have a defective battery thats all log a service call for a replacement battery
Glenn
May 06, 2009 | HP Pavilion dv6000z Notebook
New battery and charger, but still not charging
Not at all. take battery and laptop to store for proper chack.
Good luck.
Rate this
Apr 13, 2009 | HP Pavilion dv1000 Notebook
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
IBM T30. Battery will not charge.
if your laptop is working fine , plugged in the power, you are hving a problem with the battery pack. If you recently bought this, contact the resseler to replace the pack.
May 02, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
