Question about Sub-Zero Bottom Freezer Refrigerator
Freezer drain the drain tube in the freezer unit freezes up every 2-3- weeks, having to thaw and and blow out with high pressure air each time. the aluminum warming strip is still in place in the tube. would threading an 18 gauge copper wire (thermostat wire) down entire length of tube attaching to defrosting coil to keep tube de-iced help or create more problems. thanks rick
  • lin stein Sep 22, 2008
    As of late, my freezer, (right side only) has a build-up of ice on the freezer bottom lining and ice accumulates on the roller pull-out section. Then I notice water on the floor. I have defrosted for about 2-3 days then restart the freezer. It works for about 2 months and then it happens as described again. I had a repairman out about a year ago, and he suggested the above. He cleaned the unit, etc at a cost of over $300. I know it was a rip off, but it's happening too often now. Could it be the defrost timer needs to be replaced?
  • Anonymous Sep 23, 2008
    What is the correct position for the aluminum warming strip? I have the same freezing tube problem.
    Scholar:
  • 178 Answers
I thinkyou just need to take a look at replacing the defrost timer. Sounds to me as if the defrost timer is malfunctioning. It's an inexpensive part considering the cost of replacing an burned out unit or even a reapirman bill. Check into that first, let me know if you require more assistance.
Posted on Mar 16, 2008
The drain keeps stopping up
Since there is no description of what type of freezer, I will talk generic. Most freezers have some sort of drain heater. Commercial walk-ins use them. 2 types: an insertion type that go inside the drain and another type that is wrapped around the outside of the drain and then wrapped with a foam type insulation call armaflex. hope this helps some.
Jul 28, 2017 | Freezers
Kenmore side by side drain tube in freezer keeps freezing up Any solitons other than to keep thawing out the the every two weeks
try to locate the drain tube on the bottom and blow it with compressed air to clear the way for the condense water to drain out or open the freezer back panel and run hot water to see if it clears.
Dec 11, 2013 | Refrigerators
Drain tube and floor of uprite freezer is plugged with ice. Have previously thawed with a heat gun and it freezes up again in a week or two. The freezer is in our south facing garage, one car parks...
I bet you don't have that problem in the summer,It is freezing cause of the outside air in the garage gets below freezing. For a quick fix install a heater wire they make them for gutters and plumbing and just run it down the length of the tube and that will do it,short of heating your garage or insulating it
Mar 31, 2011 | Kenmore Freezers
Need to know easiest fix for clogged defrost drain tube
Wet dry shop vac. Remove the food and the service panel. Let her thaw out.
GE Bottom mount service manual
Feb 10, 2011 | GE Refrigerators
Fisher and Paykel Fridge/Freezer - Drain Freezing Up
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jul 20, 2010 | Fisher and Paykel Refrigerators
Sanyo split high pressure side tube icing
ok, on these units, if by high side line you mean the small tube going from outside to inside, that tube is actually on the low side, the metering device is in the outdoor unit. If you shut the unit down, let everything thaw then restart and find that small tube is freezing up right at the outdoor unit right away, my guess is its low on charge. I see that you put some in, make sure it is the right knid of refrigerant. they do not hold alot. Where is your suction pressure running. If you put 2 to 3 pounds with no change, you may have overcharged but that is telling you that there is a restriction in the line inside the outdoor unit, probably the filter if it has one, or the metering device itself. Let me know what you find.
Jun 16, 2009 | Sanyo Split System Air Conditioner
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
MY GE PROFILE REFRIGERATOR IS WARM, FREEZER IS FINE.
i think its not the frz drain hole blocking up but a fault with the defrost tray heater. the tray heater should keep the defrosted frost as water to drain away. it sounds as though the tray heater is not working therefore letting the water freeze as it is escaping thorough the drain hole. i would check this out by defrosting the unit and inserting a flexi rod into the otherside of the drain hole (above the compressor usually) and after clearing it if it freezes up again check out the defrost/heater system.
Apr 08, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Apr 02, 2008 | Refrigerators
Sub-Zero 550 water leak and freezing
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Sep 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
141 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
