Question about Epson Stylus CX4600 All-In-One InkJet Printer
Changed one of the ink cartridges and now all the printer does is flash all of the lights every time I turn it on. Why is that?
  • 5 more comments
  • Anonymous Jun 14, 2008
    unable to change the ink cartridge. The on light is flashing. How do I correct this and change the ink cartridge when the printer will not allow me to.
  • joalfaro Sep 09, 2008
    all lights flashing with an E in the copy window
  • bff starlight Dec 21, 2008
    It doesn't turn on. When it turns on, all the lights on with E in the "COPY" window.
  • chuck34108 Jan 14, 2009
    just installed TrueStar remanufactured cartridges and having this problem...help!
  • Anonymous Jan 25, 2009
    Please let me know how to fix this please!!
  • Anonymous Feb 06, 2009
    CX4600 was working fine, then all of a sudden went bonkers on me. All light flashing. Owner's Manual sez to take to repair shop. :-( One thinkg I think it maight be: When I ordered my last generic inks, the blue one looked like the seal had been broken becasue there was a lot of ink on it. Has worked fine, for quite awhile even with that cartridge in it --- until now. Did this cartridge damage my machine? All lights flash and then go out after a while, and printer acts deader that a doornail. WIll not turn back on with the "ON" button: must unplug and plug in again. then it will not stay on long enough to DO anything. I LOVE this machine even if it IS 4 years old.
  • Donna Sue Fraley Feb 06, 2009
    Problem Solver:
I need a new part == a roller where can i buy this roller ????
please help bob griffin basiljr6@yahoo.com 503-659-0388
Posted on Sep 02, 2008
Ink light and on/off light flashing
Turn printer off for a few minutes then turn back on. If still flashing your cartridges may not be compatible.
Jul 17, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Try removeing all the cartridges, start the printer do you get a error message code?
put them back and check the error and code again.
Thanks, waiting for your reply.
Jun 01, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Espson Stylus CX4600
Hi, Not that sure with your particular model, but pls how are you engaging the change ink cartridge mode, button on the printer or via the printer utility? If you are using the printer button, you may be double switching or the switch is bouncing. You may want to try using the Printer Utility function. Click on Start, Printer and Faxes, right click on your Epson CX4600, click on Properties, Printing Preferences, Maintenance, Ink Cartridge Replacement icon, Next, Next > follow on screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus DX4450 i have changed the ink and the ink button the red light is still on and it will not let me print?
Did you use Epson Genuine Cartridges?
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 23, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Lost my manuel !
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Pls dont forget to rate solution, thanks!!
May 02, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
