Hotpoint NLL113EYWO Electric Dryer Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer is not drying like it used to. Has been in storage for 8 months. Could that be the problem?
Anonymous
Level 3:
  • Hotpoint Master 43,501 Answers
  • Posted on Apr 05, 2010
Anonymous
Hotpoint Master
Level 3:
Answers
43501
Questions
0
Helped
10837506
Points
101584
There are a number of things that can cause an electric dryer not to heat...
Check out this tip that I wrote about that...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Dryer doesn't get hot enough to dry clothes
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this I fine then you’ll need to check the thermostat, igniter and coils. Also as its only 3 months old so it is recommended to use the warranty to avoid any further issues. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
3helpful
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
3helpful
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
