Question about Onkyo TX-SR605 Receiver
Onkyo sr 605
I have attached by sharp bd-hp20p blu ray player to onkyo 605 receiver but neither dts hd master audio or dolby tru hd light up on the display i have tryed 2 blu ray discs which support the above formats but still can get it to light up on the display
my blu ray states dolby tru hd and dolby digital plus on the player
  • Anonymous Mar 29, 2014
    in-command series is letterboxing blu ray
Tryed that still not working been told that the player will not send bitstream audio only to the receiver there for it decodes the signal on board the blu ray player so the tru hd light does not light up.
Posted on Mar 24, 2008
Check with and download the firmware update from the Onkyo web site.
Posted on Mar 23, 2008
Is there a way to read Blue ray disc from Europe on a sony BDP-S1200?
No! Sony has kindly locked there BDP range of BluRay players to the region country they were made for only and not multi region.
Jan 18, 2015 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
Unlock Sony BDP-S1200
Have you been playing cd etc from different countries. The cd units in this country will lock you out after about three tries, that is the law.
Dec 19, 2014 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
Oct 28, 2009 | Audio Players & Recorders
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
May 19, 2008 | Marantz SR-7200 Receiver
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
323 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
