Question about Nordic Ware 15040 Belgian Waffle Maker
Nordic ware Belgiam Waffler maker
I need the instruction manual for this waffle maker.
This piece of cook ware is used on the stove, it has a temperature gauge Cool-Cook-Hot. It has no model number, but the number "9" is on the gauge under the name Nordic Ware.
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Posted on Aug 25, 2008
I could use the manual, too... I'm just experimenting to see what works.
What I've found so far:
  • make sure your batter has eggs and oil (or butter) in it,
  • spray the iron lightly with Pam *before* heating it up,
  • put the iron on medium to medium-high heat,
  • just ignore the temp gauges, since they are inaccurate,
  • pour the batter into the bottom (hot) side of the iron,
  • close the iron and rock it around to spread the batter,
  • cook for 30 seconds, then flip,
  • cook the other side for seveal minutes.
  • Subsequent waffles shouldn't need more Pam.
I think the key is to keep the iron from getting too hot... and I think a slower cooking yeilds a crispier, lighter waffle.
Posted on Jun 26, 2008
I called Nordicware and they sent me directions and recipes!
Posted on Oct 14, 2008
How to use the waffler by toastmaster model# 2810R026
Directions
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
Apr 16, 2014 | Toastmaster Kitchen Appliances - Others
How to clean the stove top waffler & keep waffles from sticking?
Best wasy to keep waffles from sticking is to spray the maker with a non stick food spray like "PAM". The other way is to increase the amount of oil in the batter, but that can affect the finished look.
Jan 10, 2011 | Nordic Ware 15040 Belgian Waffle Maker
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
Instructions for Nordic Ware Microwave waffle
I have a Nordic Ware microwave waffle iron and cannot find the instructions. The instructions on the waffle iron are ok untill it says see instructions. (Which I do not have). Anyone out there have the instructions and can scan them and e mail them to me at vdanziger@gmail.com thank you
Apr 04, 2010 | Kitchen Appliances - Others
Waffles sticking and separating
try washing the inside of the waffle maker with a damp rag then dry..
Jan 05, 2009 | VillaWare 5800 Classic 4 At-A-Time Waffler
Broken shaft
I made a template of the shaft, cut out a sturdy piece of tin to straddle the break, and then screwed that piece in at both ends after securely fitting the break together. A lot of work, but the waffle maker works great!
Dec 13, 2008 | Waring WWM200PC Waffle Maker
Vitantonio waffle maker
have you open your waffle? if you already open it, check if theres a cut to the wires of you your waffle or check if there is a lost tread on something. thanks!
May 05, 2008 | The Home Marketplace 70047 Waffle Maker
Nordic Ware 15040 Belgian Waffle Maker Logo
874 people viewed this question
Top Nordic Ware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Nordic Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
